Another Supercharged TL?
Old Aug 16, 2014 | 09:57 PM
Brock79's Avatar
I came across this video and I haven't seen it before. It was published recently and they don't go into detail, but maybe this is around the corner.
Old Aug 16, 2014 | 10:28 PM
prototype kit.
they are hung up on tuning.
p.s. if they are still using the MP62 as the blower, it was very undersized for the 3.2 TL. MUCH less for a 3.7
Old Aug 17, 2014 | 08:33 AM
Brock79's Avatar
prototype kit.
Yea, I know it's undersized, but it's on a different car which means they might have made some advancement, I know all about the lack of a tune for the 4G.
Old Aug 17, 2014 | 09:19 AM
^they've been working on this kit since 2010.
if they really did achieve 100 extra hp from the blower, that indicates they used a bigger blower.
we've(3rd gen TL community) retrofitted the MP90 into the MP62 housing and gave greater results.
with the help of hondata, we've seen exceptional numbers from the ct supercharger.
however, it brings heat!
you'll need adequate cooling!
whether it be with Meth or an aftermarket intercooler.
Old Aug 17, 2014 | 09:43 AM
Brock79's Avatar
Any time you run a supercharger as an aftermarket set up you need an inter cooler. I know everything that has been tried and what it takes to get this going. I posted the video because it looks like they have gotten it closer. 100 hp should be expected, not much more and not really any less. This is a 300hp+ engine to start with. I assume the kit will be around 5-7 grand, depending what will be included. Most kits only include the supercharger and all the hardware and brackets. You would also need the tune, larger injectors, larger fuel pump and the intercooler. There are a few other minor things that might need changed as well. Justin, when you're talking FI you're way behind in knowledge on this one. I've added supercharges and turbos onto almost everything I have owned since 2002, that includes quite a few different cars and trucks.
Old Aug 17, 2014 | 09:58 AM
to be frank, they've been working on it since 2010.
I think you're a little bit behind on the curve.
they are stuck on tuning.
Old Aug 17, 2014 | 12:31 PM
Brock79's Avatar
Read my above posts, I noted that I am aware of the tuning situation. I think you're a little behind on the curve. It's ok though, I know you just started learning about cars and how they work 5 years ago. You have a lot to learn, tell me again how you can degree a cam without actually taking measurements from the engine it's going in.
Old Aug 17, 2014 | 01:30 PM
^this isnt a dick swinging contest.
the video you linked did not provide any new information.
Old Aug 17, 2014 | 01:44 PM
wreak's Avatar
Kit probably won't be anymore than 5k at the most and it will probably include injectors like every other kit they've ever offered that needed them.
Old Aug 17, 2014 | 03:01 PM
Brock79's Avatar
Yea it's not, so no need for you to go on any further about something you don't understand.
Old Aug 17, 2014 | 03:04 PM
Brock79's Avatar
You hope so, but don't count on it. I bet it's an add on package with the fuel pump and fuel rails if needed, and the tuner.
Old Aug 17, 2014 | 03:17 PM
wow.
you continue to insult me.
I thought we were over that.
like previously stated; you dont have to keep pulling out your e-penis to show me how big it is.
I'm not interested.
No means no, Brock79.
Old Aug 17, 2014 | 04:02 PM
Edward'TLS's Avatar
6G TLX-S
Brock79, the so called "Kit" for the 4G TL, is one with miscellaneous parts thrown together, untuned and untested.
That thread was created way before the date you joined AcuraZine. See below.
" 2009-2012 TL Super Charger Kit " :
https://acurazine.com/forums/4g-tl-performance-parts-modifications-295/2009-2012-tl-super-charger-kit-887210/
And many 4G TL owners have been dying waiting forever for a proper supercharging kit to come out into the market.
So if you can make good use of your expertise in turbos and superchargers, and come up with a proper forced induction kit for the 4G TL, then a whole bunch of us will be loving and kissing you.
Old Aug 17, 2014 | 04:05 PM
Old Aug 17, 2014 | 04:31 PM
odessa's Avatar
Pre-Registered Member
Old Aug 17, 2014 | 04:38 PM
wreak's Avatar
Brock79 is our resident know-it-all, most of us probably "don't understand" much of anything going on inside his head lol
Old Aug 17, 2014 | 04:48 PM
Chief F1 Fan's Avatar
"How Not to Take Constructive Criticism 101."
Old Aug 17, 2014 | 05:20 PM
Mr. Maker's Avatar
Old Aug 17, 2014 | 06:12 PM
#1 STUNNA's Avatar
Sanest Florida Man
He probably won't be able to respond tonight he's preparing for his fight with John Cena
Old Aug 17, 2014 | 06:31 PM
Brock79's Avatar
wow.
I'm not interested.
So you write this post after you remove the getting owned links? Now we are ok? I don't think so.
Old Aug 17, 2014 | 06:33 PM
Brock79's Avatar
https://acurazine.com/forums/showthread.php?t=887210
I'm aware of the other video and silver car from 2010, the video above is a new video with a different TL and was posted only a few weeks ago, so I'm hoping it means there is a breakthrough around the corner. My expertise in FI has nothing to do with writing programs and tunes.
Old Aug 17, 2014 | 06:37 PM
I happened to remove the links last night because I thought we were done being childish.
Old Aug 17, 2014 | 06:40 PM
Brock79's Avatar
Never said I was a know it all. But I do see you're back with Justin after he was bashing you. I do know about power adders though and this is one subject that I know majority of the members on here have no experience with. If this set up ever works will it need a return rail or no? What size injectors? Add a pump or just a larger fuel pump? Will we need A/F gauge or will the tune be able to adapt the engine to the new A/F. Will smaller pullies be an option? There are a few more things I can go on about. I would be one of the first to add this kit to my TL. Most kits come in 3-4 different level options, being from just the supercharger and brackets all the way up to a full kit ready to go.
Old Aug 17, 2014 | 06:42 PM
Brock79's Avatar
You keep links up for a few weeks starting the childish behavior, so I'm suppose to be cool with it once you decide to take them down? How does that work exactly? You attack me and I'm just gonna sit here and wait for you to be done? This is a thread I started and had nothing to do with you, you don't even own a 4G and you have no idea about FI, so how does this thread involve you?
Old Aug 17, 2014 | 07:12 PM
Mr Marco's Avatar
Brock, stop giving them what they want. It's a game you can't win.
Old Aug 17, 2014 | 07:19 PM
Mr Marco's Avatar
The more you try to defend yourself the more they get off. And they have played you really well. I mean c'mon Brock...just look at my signature. You're letting them get the best of you.
I advise you to use the forum as it suits your needs and put idiots like Majofo on "ignore."
Old Aug 17, 2014 | 07:31 PM
Majofo's Avatar
Doesn't your dick have to swing to enter..
Italidildo = Brock
Coming from the most ignored member on the board..
Old Aug 17, 2014 | 07:42 PM
usdmJON's Avatar
How does one troll bait themselves... come on Brock.
P.S. I've got the entire TL community on ignore.
Not brock though. I like reading his posts for the lulz.
Old Aug 17, 2014 | 08:16 PM
Brock79's Avatar
Just for that I gave you a thanks, lol. It really doesn't bother me at all, I actually ran into a member in Westchester, name withheld because I'm not an asshole. Anyways he brought up my screen name and said what a douche I was, I said that's funny, what would you do if he was here right now? The member said I would smack some sense into him. I said smack away when you're ready, he apologized, and said no it's cool I was just joking. When I insisted he slap away, he got real nervous and got in his car for some reason and sped off. Anyways that just proves my point, a lot of people talk shit on here but in real life it's a different story.
I just wanted to post an updated video of a supercharged TL, I guess that's to much for some members to handle though.
Old Aug 17, 2014 | 08:19 PM
Brock79's Avatar
majofo is quite personable once you get to know him. He gets his kicks from this stuff, right now he's rubbing one out reading this post. He's a hype man that's all.
Old Aug 17, 2014 | 08:23 PM
P.s. you do know we have the same engine right?
everything you just mentioned has been done to the 3G TL.
the CT kit comes with everything you need, as stated in the video that you posted.
the things you mentioned are optional to get more power.
since the blower is already underdriven, it was a bad idea in the past to use the High boost pulley.
we upgrade to the RDX injectors. they are 410cc.
we also upgrade the fuel pump.
Old Aug 17, 2014 | 08:26 PM
here is my current project:
J32(06 TL) short block with J35 cams (07-08 TL-S) inside J37 heads (07-09 MDX)
Old Aug 17, 2014 | 08:31 PM
Brock79's Avatar
while are engines are close to being the same they are not, I have the 3.7, not the 3.5. While they do share a lot in common they are not quite the same. I have never stripped one down of either size, but I suspect the largest difference are the heads and connecting rods. Besides that yes they should share the same block and many other components. The RDX is a 3.7 as well, I'm pretty sure, so that would be the same engine that was in the TL in the video. They did label it as an AWD version and it did seem to have the SH AWD front end as well. So yea those injectors are no good if you're adding 100HP. One thing I'm not sure about is if the 3.7 could handle that much extra boost. Would Honda use forged internals? I doubt it, if they did, then boost away and hope the block is rated for at least 600 HP.
Old Aug 17, 2014 | 08:32 PM
^the turbo rdx injectors are 410cc which will handle any kind of boost you throw at it.
Old Aug 17, 2014 | 10:33 PM
Majofo's Avatar
Old Aug 17, 2014 | 10:44 PM
Ken1997TL's Avatar
What a load of BS.
You need to just acknowledge that your information and perceptions are a bit incomplete, apologize, thank the member who shared the information and move on.
Old Aug 17, 2014 | 10:46 PM
Majofo's Avatar
Old Aug 17, 2014 | 10:56 PM
#1 STUNNA's Avatar
Sanest Florida Man
No, it's because it didn't happen, that's why you won't name them because they'll call you out on your bs...
Old Aug 17, 2014 | 11:08 PM
1Louder's Avatar
Old Man Yelling at Clouds
Oh really?
I think you're a little behind on the curve. It's ok though, I know you just started learning about cars and how they work 5 years ago. You have a lot to learn…
…you don't even own a 4G and you have no idea about FI…
You just really don’t hear yourself, do you?
If you have to keep saying you’re an expert, you are not an expert. If you spent as much time trying to be helpful as you do insulting people trying to engage you in conversation, your expertise would be self-evident. If you're such and expert, teach instead of criticize.
You could be a world-renown expert in FI, but when you communicate with people like this all they'll hear is a fool.
Old Aug 17, 2014 | 11:35 PM
Mr Marco's Avatar
^ Brock, I give up. Continue on.
