Unplayable File
Old Jun 30, 2009 | 12:18 AM
NYSH-AWD's Avatar
Question Unplayable File
Has anyone tried to connect their iphone and get a message that reads "unplayable file" on the car's audio screen? It happens to me every time, I have to unplug the USB ipod interface and retry with the car radio on. I think it has to be a glitch on my phone? unless you guys are having the same issue?
Old Jun 30, 2009 | 02:15 AM
bmode's Avatar
Same issues here. Ever since the new 3.0 update, I've been having at least 2 issues a day as I unplug and plug in my iPhone at least 4 times when I'm out and about running errands or at clients.
First issue, the iPod started to play music then just stopped. So I unplugged it, then plugged it back in, then all good.
Other times I've had no audio but the read out still displays the info on the Nav screen.
The positive is the Bluetooth audio is stable and has good quality and range.
Old Jun 30, 2009 | 09:35 AM
PaulNY's Avatar
that happens to me when the phone decides that it wants to use the HandsFreeLink without me telling it to, i have to change the audio source and then it plays (found that out after turning the volume alllll the way up to make sure i wasnt crazy, then noticed HFL was active, switched it, and nearly went deaf)
I just leave my iPod classic in all the time now, its easier than trying to screw with the 3gs while driving, I'll use it for BT audio and phone calls, but generally its unplugged
Old Jun 30, 2009 | 09:44 AM
buckvegas's Avatar
I am a bullet proof tiger
Same problem here with the 3g-s. I have to unplug and plug back in, then it works.
Old Jun 30, 2009 | 10:14 AM
CleanCL's Avatar
Happens to my USB fob as well, same fix, unplug and plug back in.
Old Jun 30, 2009 | 12:39 PM
MatthewMccann's Avatar
According to the dealership they haven't heard complaints about this. My iPhone (original) and iPhone 3g both do this now with the 3.0 upgrade. I downgraded them back to 2.1 software and it works fine. So this tells me that Acura needs to software update the nav system to correct this. --- Please call your dealership and complain so they fix it! ---
Old Jun 30, 2009 | 10:10 PM
NYSH-AWD's Avatar
Thanks for all the input! I wanted to know in case I needed to restore my iphone.
I think the trick is to power the car radio before connecting the USB interface to the iphone, it's been working on the first try for me thus far.
Old Jul 1, 2009 | 11:13 PM
CUBSH8R's Avatar
It's going to be interesting to see how 3.1 effects things further. It's due out soon and one of the items is voice control over bluetooth. I doubt there is anyway to make this work with hands free in the TL, but that would be sweet if you could send play commands for the BT audio.
Old Jul 2, 2009 | 12:12 AM
PaulNY's Avatar
I'll throw the 3.1 beta on my old 3G tomorrow or friday and let you know if it affects the ipod link in any way
Old Jul 3, 2009 | 06:33 PM
PaulNY's Avatar
updated my 3GS to 3.1 beta, plugged into TL today, recognized it right away as ipod, took like 25seconds for it to read all the songs and start playing...
Old Jul 4, 2009 | 05:48 AM
bmode's Avatar
It's hard for two company's (Apple/Acura) to be on the same page. While someone is thinking of telling Acura to get it right, I'm thinking Apple should be more backwards compatible as the iPod functions were much better before. I've also had about 3 dropped calls in high cell sight areas since the 3.0 update? I look forward to 3.1 as the upgrade after the big one usually sets things right. Oh and I'm still getting the the quick drop. When you get into the car and the iPod "resumes" play and then drops out in 4 secs. Odd one.
I'm not complaining, it's still the bomb when it all comes together!
Old Jul 7, 2009 | 08:51 PM
Omega1969ca's Avatar
6th Gear
I to am having the same issues with the 16GB Iphone 3G since ugrading to 3.0 firmware. I have to plug the iphone into the USB cable sometimes multiple times before it will read it and even then it will occasionally lose sync with the iphone. Very annoying and I hope this is fixed soon.
Old Jul 8, 2009 | 09:15 AM
BleuM&M's Avatar
User-approved
bmode, have you tried a reset? I've had zero issues with my iphone 1G before and after 3.0, none with the 3GS with the 1G Touch still running 1.x.
Old Jul 9, 2009 | 03:05 AM
bmode's Avatar
Reset what?
Old Jul 9, 2009 | 10:20 AM
BleuM&M's Avatar
User-approved
Reset what?
Sorry, I meant restore. Back up and restore your iPhone, or cycle off and on.
Old Jul 9, 2009 | 07:59 PM
bmode's Avatar
Oh yeah, do it almost every night. Still getting unplayable file at first connect, then the second connect is all good. I'll wait for 3.1 iPhone update before I go off.
Old Jul 12, 2009 | 06:31 PM
Sphyrna's Avatar
The other day it took me about 4 tries before it would read my iPhone. Of course it did this when I was showing off my car to a coworker.
Old Jul 29, 2009 | 01:08 PM
DagzTl's Avatar
3rd Gear
does it matter if the songs were "bought" from itunes? as it says in the manual?
Old Aug 2, 2009 | 10:08 PM
6th Gear
Unfortunately, the latest firmware for the Iphone (3.0.1) does not fix this issue. I certainly hope that Acura is working on a fix for this annoyance.
Old Aug 4, 2009 | 08:52 PM
GearDriven's Avatar
Unplayable file usually show up if you connect it while on the videos screen. Also if you are note getting audio, tap the little "B" bar on the bottom as it is probably playing over HFL instead of the dock connector...
hope that helps.
Old Aug 4, 2009 | 09:10 PM
crxb's Avatar
I see it sometimes when I plug in my iPod or phone and the plug doesn't go in exactly right. I restart the device (ie shut down the phone and turn back on ) and it corrects the problem
Old Aug 6, 2009 | 08:38 AM
Donmachete's Avatar
5th Gear
unplayable file ipod touch
I am having this problem with the ipod. I have to remove it and then plug it in again. Has anyone figured out how to fix it yet?
Old Aug 24, 2009 | 10:40 AM
Nodnarb901's Avatar
FWIW: I am a service advisor for Acura and am having the same problem with my Iphone 3g and 09 SH-AWD TL. I mentioned something about it to my Acura rep when he was in last week and he said he would pass it on as he has not heard of this problem yet.
Old Aug 28, 2009 | 05:31 PM
Nodnarb901's Avatar
I just got off the phone with tech line and told them about the problem, they have not heard about it yet, and now they are aware of it and said they will be working on it ASAP. They suggest that: the TL was built around the older 2.0 OS, when the 3.0 update came out everything changed and the iphone would no longer communicate with the TL. The problem is as soon as Acura comes out with an update, Apple will have an update that will be ahead of what Acura does. This is one reason the music link acessory was discontinued on the older TLs.
I'll post any more updates as I hear about them.
Old Aug 29, 2009 | 01:18 AM
6th Gear
Well, I have had enough with this issue, and the sluggishness (it has been slow since the upgrade as well) of my 3G Iphone since the 3.0 update. It took some patience but I was able to downgrade the firmware back to 2.2.1. At the end of the day, I would rather have the phone work and have it sync properly with my car than a few extra features I didnt really use anyways. It is clear to me that this update pushed the 3G beyond its processor capability. I beleive that it was likely timing out when trying to sync with the car as the operating system while good for the 3GS was just too much for the last generation of the iphone. I also wasnt going to hold my breath waiting for Acura either. I had called the dealer who called the tech line a few times over the past few months and they just kept saying they didnt know a thing about it and noone had raised this (right). Anyways, hopefully they can find a way to resolve this. As a suggestion, I would not attempt the firmware downgrade unless you are fairly computer savvy as it is fairly involved.
It was good to hear that I was not alone on this issue.
Thanks Everyone
Bryan
Old Sep 11, 2009 | 11:04 PM
6th Gear
Can anyone confirm if 3.1 fixes this issue?
Old Sep 12, 2009 | 05:57 AM
dwest1023's Avatar
It does not.
Old Sep 12, 2009 | 10:27 AM
6th Gear
Good to know. There is no way I will go back to 3.0/3.1 until this is fixed.
Old Sep 12, 2009 | 01:13 PM
Nodnarb901's Avatar
FWIW: I got a call from techline yesterday asking if I unplug/replug the iphone in does it help. it did not. then they told me to leave it plugged in and turn off the car and restart leaving plugged in, did not change anything. I told them I volunteer to be the guinea pig to try a few things to get this resolved. I'll keep ya posted if I hear anything.
Old Sep 12, 2009 | 04:07 PM
PaulNY's Avatar
I tried my 3GS today, running 3.1 and had no problems, car was running, unplugged my other ipod, plugged in 3GS, no issue, music played...tried 3 times, worked fine all 3 times
Old Sep 12, 2009 | 07:10 PM
bmode's Avatar
Is your Bluetooth on? Because I still have issues with 3.1 installed on 3GS. I have to reconnect the iPhone because the Bluetooth interrupts the connection, after that it's all good, but really frustrating as the data port on the iPhone is taking a beating.
When I turn off the Bluetooth on the iPhone is perfect. The odd one is when I have it turned off and the iPod is running fine, then turned on the Bluetooth at a stop light, I lose audio on the iPod. The visual is still there and the track is running, but just lost audio.
Old Sep 12, 2009 | 08:21 PM
PaulNY's Avatar
my BT is on, I've been using the iphone for stereo BT a lot this week, and i always have bt on for HFL
Old Sep 14, 2009 | 04:18 AM
bmode's Avatar
I don't know man, you're a lucky one I guess. I've been struggling with it and at this point I'm just used to plugging it in twice. I ran a series of tests, like pluggin' it in with the Nav off, WIFI off, BT off, XM on, FM on, etc... and it still drops audio. Oh well, it's a bit more work, but still happy with it.
Old Sep 15, 2009 | 10:22 AM
fusiongt's Avatar
I use usb flash drive instead of ipod, but on some mp3 files it just stop playing. Unplug and plug back in solves the problem but it's annoying. It's more of a software issue i think. or maybe bitrate problem.
Old Apr 4, 2011 | 04:38 PM
vinnier6's Avatar
just to restart this thread, still a problem with my ipod touch...for the most part it works fine, just leave it plugged in, but sometimes when i disconnect it to add some music, when i put it back in the car i get the unplayable file until i plug it in and unplug it 50 times....
Old Apr 4, 2011 | 06:36 PM
BigTSX's Avatar
Pimp Master T
I've been having problems with the handsfree thing mentioned above
Old Nov 22, 2013 | 06:56 AM
Jcook's Avatar
i have a iphone and a second gen ipod. my iphone works fine when i plug it in the usb to play music but my ipod says 'unplayable'' i tried disconnecting it couple times but still nothing any ideas??
Old Nov 24, 2013 | 08:01 AM
dwest1023's Avatar
Reboot the iPod.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
UA7_Ando
Sep 28, 2015 07:53 AM
