Temperature
Temperature
Hi, im new on here so and just need some clarification. Everytime I turn the fan button to on i notice that the a/c in function always on, even when I turn it off later the a/c will be on if turn the fan on.. Is this a default feature where we have to turn the a/c off each time we hit the fan button to on??.
Also the auto temp button when I hit mine, it goes full blast and a/c. How exctly does the auto feature work?.. Please explain and thanks in advance
In the Auto mode, the A/C compressor always stays on producing cool air.
According to the displayed set temp, the computer then controls the amount of "A/C cool air" and "heater core hot air" getting mix together and getting blown out of the various vents.
auto feature brings the temp down inside cabin by reading the outside temps.
and yes, if you want the fan on only without ac being on you will either have to push the ac button everytime or set your temps to where a/c will not go on.. like 72 degrees or so
This is what I do: turn fan on. Turn off AC. before I get out of the car, I turn the fan to low. I leave it like that and manage the temp fan from there. This stops the AC from always coming on, but your auto feature will not be working. 6 in one 1/2 dozen in the other. I just really don't like AC unless it is really hot out.
damn.. i use my ac all the time.. damn hot weather in california.. also i dont like smelling exhaust fumes on the fwy and i hate dust.. so my windows are always closed unless i go through drive through or im chillin in my car.
If you have Tech Package, just set the fan speed, temp, and AC off and set it to 1or 2 depending on fob you have and your settings should hold. I set my default temp settings for winter/summer because I am in Canada. Brrr....
rockyboy
Aug 4, 2024 10:35 AM
CostcoFanAUS
Sep 18, 2015 06:05 AM
Sep 17, 2015 09:01 PM
