Stereo Install '09 SH-AWD
Old Apr 17, 2012 | 08:05 AM
keathb's Avatar
I am currently upgrading my entire stereo system and I have had a couple of people ask for pictures as I go along.
The first thing I did was remove all door panels, rear seat, deck lid, and all trunk linings. I installed dynamat on both interior surfaces of the doors (inside of the outer skin, and where the stock moisture barrier was).
Old Apr 17, 2012 | 08:08 AM
keathb's Avatar
Sorry for the poor quality pics, my cell phone has an 8mp camera but saves the pics as tiny tiny files....
I will take pictures of the rest with a real camera
Attached Thumbnails Stereo Install '09 SH-AWD-1334430041479.jpg   Stereo Install '09 SH-AWD-1334430040328.jpg
Old Apr 17, 2012 | 12:10 PM
Edward'TLS's Avatar
6G TLX-S
Putting Dynamat inside the rear doors will also make the rear doors close with a more solid sound, just like the front doors.
Old Apr 18, 2012 | 09:38 AM
keathb's Avatar
Factory Amp
Tapped into the factory amp and connected my hi level converter (turns speaker wire into RCA plugs). Don't worry, it will be nice and pretty when I finish and put the trunk lining back in. More to come tonight/tomorrow when I connect the sub amp as well.
Old Apr 20, 2012 | 06:48 PM
binarythrottle's Avatar
Thanks for taking the time to document the process, I want to do the doors too.
Old Apr 21, 2012 | 11:10 PM
keathb's Avatar
Talking
Sorry for not posting any new pics yet, been working late and haven't gotten to spend much time on this project during the week. I did finish it up this afternoon and will post the pictures tomorrow morning. To answer a few questions about the car and the complete setup:
The car does have the tech package and I am still using factory head unit. As far as I know there isn't an adapter offered that will allow the use of an aftermarket head unit. I wanted to keep the factory one anyway just to be sure I don't lose any of the functionality of the tech package.
I put a set of MB Quart 6 1/2" componets in the front doors (tweeters mounted in the factory locations in A pillars) and a set of memphis audio 6 1/2" componets in the rear deck. I removed the 4" speakers from the rear doors and covered the openings with dynamat. The factory center channel is still operational since I have the ability to simply turn it down with the audio controls and therefore not have to worry about blowing it.
The newly added componets are powered by an Alpine 4 channel amp and sound amazing (and yes, HUGE difference over the stock setup).
I removed the factory sub and replaced it with a Kicker comp 10" sub in the enclosure I spent three days working on. It is powered by a mono Alpine amp running at 150W rms.
Given the crazy contours of the trunk, I only had room for one subwoofer with the correct volume but if I really wanted to, I could have extended the front of the box a bit farther out and shortened the height (to fit under center passenger seat belt) in order to put both subs in. I will say that I am very pleased with the sound I get from the one sub.
Pictures will be uploaded tomorrow for you all to see and I wish you all the best of luck in your stereo endevors
Old Apr 23, 2012 | 10:12 AM
keathb's Avatar
Here are the pics of the sub enclosure and the wallI designed for the Amps to be mounted on. Just for the record, I can access my spare tire still.
Attached Thumbnails Stereo Install '09 SH-AWD-1335026385528.jpg   Stereo Install '09 SH-AWD-1335028319107.jpg   Stereo Install '09 SH-AWD-1335028545434.jpg   Stereo Install '09 SH-AWD-1335028737852.jpg   Stereo Install '09 SH-AWD-1335031499631.jpg
Stereo Install '09 SH-AWD-1335039899649.jpg   Stereo Install '09 SH-AWD-1335042773375.jpg
Old Apr 23, 2012 | 11:52 AM
EazyRider562's Avatar
Is this tech package?
Old Apr 23, 2012 | 01:12 PM
keathb's Avatar
Yes it is tech package
Old Apr 23, 2012 | 09:14 PM
eggyhustles's Avatar
looks good
those kicker subs belong in ported, though.
Old Apr 24, 2012 | 01:23 PM
keathb's Avatar
Thanks eggy, I did want to port them but I was not sure what to tune them to so I just sealed it up. I am surprised at how well the sealed box sounds. If you have any info on where these 10s like to be tuned to, let me know.
Old Apr 24, 2012 | 05:34 PM
Not sure why your upgrading if you already Tech package bro.?
Old Apr 24, 2012 | 06:08 PM
Low.
28-32
Old Apr 24, 2012 | 08:55 PM
keathb's Avatar
Because the best factory stereos can't compete with the sound quality of the worst aftermarket set ups I have ever installed. This set up I just put in here could compete with some systems that I have won contests with.
Ever heard the phrase "the best turd is still a turd"? That is how I feel about factory sound systems.
No offense intended
Old Apr 24, 2012 | 08:59 PM
keathb's Avatar
Originally Posted by eggyhustles
Low.
28-32
Thanks man. I will build another vented box and see how it sounds this weekend. Just a few screws and I can get behind the wall and swap boxes
Old Apr 24, 2012 | 09:25 PM
Goodluck.
Shoot for 30hz
Old Apr 25, 2012 | 11:31 AM
Brew0360's Avatar
No offense intended
Welcome to the 4G TL Aftermarket stereo install club. You may want to search to see what others have done. I gutted my system (except the HU) a couple of years ago. Also, dynamatted the entire car from the firewall to the trunk. Didn't like the factory HU limitations so added an Alpine PXA-H701 processor. That made huge difference.
Old May 1, 2012 | 01:32 AM
Ladkahaidesi's Avatar
9th Gear
Where is the factory amp?
Old May 1, 2012 | 02:12 PM
vinnier6's Avatar
because everything factory can be improved upon....
Old May 2, 2012 | 05:17 AM
KarKraze's Avatar
Nice job keathb ,that Kicker does sound good in a sealed box,how do i know? because i have one lol.
Old May 16, 2012 | 06:56 PM
keathb's Avatar
Passenger side trunk. There is a picture of it above. Behind wheel well
Old May 17, 2012 | 12:56 PM
Mr Marco's Avatar
My lady already bitches about the small trunk size...
Old Sep 13, 2012 | 10:15 PM
sympley's Avatar
did you bypass the factory amp? Or is it still powering some speakers.
snorf
Nov 4, 2019 06:44 AM
Kamakanani0
ILX Audio, Bluetooth, Electronics & Navigation
Nov 4, 2015 05:44 PM
TxRzrBk
Sep 17, 2015 01:07 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Gianni Formica
Sep 7, 2015 08:28 PM
