Rearview Mirror
Rearview Mirror
I made a DIY stealthcord for my V1. I was wondering if someone can tell me which two wires I should stick the pins to before I try all combinations?
From the back of the mirror:
Y-B-Y. Black is the ground I assume. Which one should I go for the hot one.
Thanks in advance.
Thanks in advance.
Put a voltmeter on it... check the polarity...
Autofahrer
Haha... Just did that yesterday!
If you look back of the mirror: the far left one is +, the middle one is -.
If you use the far right one, your V1 might turn off in reverse.
I literally just did that yesterday for my 9500ix.
The one with the tape is Ground!
It is very tight clearance in there as I have to nudge the cable up to stick the PINs in, in the process I broke the d-sub connector. Luckily it was a DIY so I get to do it again
Autofahrer
How were you able to break those pins? They're pretty sturdy
The DB9-pins fit right in the holes below the actual cable-pins.
I used pins like this one:
And on this RJ11-cable, green is -, red is +12V. Just for future reference
Stew4HD (01-06-2012)
Thanks. I got the polarity correct since I tested it with a volt meter against the power adapter from the unit.
I think I accidentally hit the insualted end with my soldering iron so it was prone to snap. Plus I didn't strip enough of the black casing to allow more maneuver room. These should be corrected tonight.
Oh, I just used some crimp type connectors from RS. They re probably not as sturdy as the ones you used.
Wait, are you sticking the pin in the holes below the one where the cables are going in? I thought those were blanks for other pins. How do you get power from there?
Autofahrer
This is driving me nuts. I made a nice wire and measure that there is no resistance. I plug the cord into the mirror and i measure the voltage across and there is like 13+ volts. Yet it would not power my radar detector (V1). I check the detector with the V1 cigarette lighter power adapter and it works with the factory cord. I plug the wire I made into the same power adapter and I still measure the same voltage. So wire is okay, detector is ok, power coming out of the rear view mirror ok... why wouldn't my detector get power?
To add insult to injury, in the last try where I decided to give up and have a shop do it, I forgot to turn off the engine and shorted the circuit. Car wouldn't start. I spent like 2 hours with my coworker hunting for the burned fuse and finally found that the Meter fuse is burned. In the process, I dropped a spare 7.5 AMP fuse in the engine compartment, landed in the undercarriage tray, lost the fuse puller in the passenger side fuse box where it shall remain and I have to borrow one from my coworker. It took 2 rounds because I missed the fuse break the first time around.
Turned out the meter fuse is 7.5 AMP as well and I don't have a spare one anymore. Luckily, there are 7.5 AMP fuses in the slots for BSI and SH-AWD. Since I have neither I pulled the BSI and used it for the meter. I need to buy a bunch of fuse and a puller now.
I think I will have a stereo shop do the hard wiring for me...
Happy ending. The green wire is the hot one for V1.
I found the answer in YouTube of all places. I think I made the mistake since most DIY guide refer the red wire as the hot wire and the green one as ground. I guess for the Passport that is the case.
ejbrandt (05-02-2012)
Received 6,470 Likes
Tux, in the lower right hand corner of each post, the middle icon is a Multi-Quote button. This allows you to respond to multiple people in one response/posting.
Give it a try!
Give it a try!
Thanks Steven. I will keep that in mind next time. BTW, can I edit my post afterward to correct mistakes?
ITSJESTER
17
12-06-2018 02:29 AM
soupi
14
11-15-2015 11:15 AM
