iPhone 5/Bluetooth/Spotify
Old Oct 16, 2012 | 12:05 PM
Dallasboy's Avatar
Ok, well I tried to run spotify for the first time on the new iP5. Bluetooth is connected and nothing. Is there a setting in the phone I need to change?
Old Oct 16, 2012 | 01:59 PM
dwest1023's Avatar
Did you select Bluetooth as the source on the radio? Can you stream any other music source from your phone? Did you see what source your phone was connected to?
Old Oct 16, 2012 | 02:43 PM
Dallasboy's Avatar
Yes, selected bluetooth as source. I haven't tried any other music service, but it is setup like my iP4 which I streamed spotify all the time. One more thing, it was plugged into the USB (to charge on way into work), but always did that. I need to play around more...just tried it out quickly this morning, but it was playing and did not stream and it is connected via bluetooth (used the HFLink already before just fine).
Old Oct 16, 2012 | 08:06 PM
erdoc48's Avatar
06 Anthracite TL
There is a glitch with iOS 6 that I discovered today. I have a Pioneer head unit in my MR-2 Spyder and my iPhone has iOS 6 on it (just upgraded a few days ago). The point is that iOS 6 has a Bluetooth issue that doesn't work well for streaming audio (in my specific case, audio will stream from my music and Pandora, but the controls and ability to toggle through my music is impaired). The problem is well documented on the net, and Apple is working on a fix for it.
My wife's iPhone has iOS 5.1.1 and it works fine with my head unit. It's a known problem with iOS 6 and hopefully there will be an update to iOS 6 soon.
I don't have a 4G TL, but since the iOS is at fault here, I thought you may want to know.
Old Oct 17, 2012 | 02:35 PM
Dallasboy's Avatar
Quick update....the music is playing through the iPod USB link when plugged in. Still no bluetooth audio stream if not plugged in and BT is paired because it works with HFL.
Old Oct 17, 2012 | 02:46 PM
dwest1023's Avatar
I have IOS6 on my Iphone4 and I have no problem with any function.
Old Oct 17, 2012 | 02:48 PM
dwest1023's Avatar
I hae a Iphone 5 on order, so I guess I will find out soon what issues I will have. Another person on the forum bought an Iphone 5 and said all worked well.
Old Oct 17, 2012 | 08:25 PM
pimpin-tl's Avatar
This is a known glitch with ios 6 and it is already been mentioned by Apple on their support forums.
mlody
Dec 4, 2019 02:11 PM
rockyboy
Sep 25, 2015 10:44 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
Barb Jackson
Sep 15, 2015 02:27 PM
IndycarFaster
Sep 11, 2015 02:52 PM
