How to copy new navigation DVD 4.81
Old 12-09-2009 | 03:24 PM
nianmo's Avatar
I am trying to make a copy of new navigation dvd 4.81 for my 08 TL. I used 4.7g DVD but it says not enough space. help me! actual size of original dvd is more that 7g.
nianmo
Old 12-09-2009 | 03:26 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Hello and welcome.
I don't believe you can copy the navigation DVD with a regular DVD burner.
Old 12-09-2009 | 03:44 PM
Kingmeow's Avatar
Double Layer? But you probably can't copy it as it's probably burned in a non-standard way or if you can copy it, it's tied to the car and you wouldn't be able to use the copy elsewhere.
Old 12-09-2009 | 06:28 PM
BigWopHH's Avatar
You may be able to if you use a program like Nero that allows for overburning to squeeze every MB out of a disc...
http://forums.guru3d.com/printthread...hreadid=143326
Old 12-11-2009 | 12:08 PM
nianmo's Avatar
yes it was double layer. I did burn it with nero 9. software loads into my navi, but it is unable to read the disk after loading software.
Old 12-11-2009 | 09:38 PM
Kingmeow's Avatar
A sign that there is copy protection involved.
Old 03-22-2010 | 09:21 PM
Transcend76's Avatar
6th Gear
The DVD is encrypted. You'll need something like DVDFab that can decrypt the original DVD, read it, and write a new one. And yes, the DVD is dual layer.
Old 06-03-2010 | 10:45 PM
TL-S Driver's Avatar
I would like to know if anyone has made a working copy, please, please post. Thanks
Old 06-04-2010 | 09:29 AM
Pete2010's Avatar
Won't matter, I believe you need to activate it with a code based on your VIN number... Based on other people who updated their Nav.
Old 07-30-2010 | 08:38 AM
Keyblade's Avatar
The best way is to burn it with a MAC and use double layer disc.
Old 07-30-2010 | 08:45 AM
08A-SPEC's Avatar
it wont happen, tried with many different software apps and about 5 different brands of disks.
Old 09-08-2010 | 11:42 AM
aditya2608's Avatar
It simply does not work
I have a friend who works for Acura. According to him it is simply not possible to make working copy of a navigation DVD
Even I have tried it with many different combinations. Didnt work.
Old 02-14-2011 | 10:57 PM
rsteagall's Avatar
There is probably a specific "layer break" that needs to be set when burning the image. I've run into this before when messing with various gaming systems. You need to read details of the original disc where the 2nd layer starts and layer 1 ends. Again though... I think there is an activation code or sorts needed to actually use?
Old 02-14-2011 | 11:08 PM
Bearcat94's Avatar
AZ Community Team
Sorry fellas. This thread should have been closed when it started.
The site cannot allow discussion/instructions on copying Acura copyrighted material. Too much risk for the site.
Hope you all understand.
AJRozsa
10-05-2015 07:50 PM
RadiantCycles
ZDX
09-26-2015 09:18 PM
AcuraKidd
09-25-2015 11:18 PM
Quick Reply: How to copy new navigation DVD 4.81
