Help with adding wallpaper via usb
Old Jul 25, 2009 | 09:55 PM
benzboy429's Avatar
Hi All,
I read all the posts on adding wallpapers and I don't know what I'm doing wrong. I'm using JPG only each file is under 6gb, im using a Sandisk 4gb cruzer (btw, when i put mp3s on it the car plays them fine). I tried putting them in a folder called wallpapers and i also put them directly onto the usb drive and neither worked. I also went as far as trying to upload them from my ipod nano but that didn't work either. Any suggestions? Ideas?
I sat in my car for a 1/2 hour with my laptop trying all different ways to do it, but its just not working. I don't get it...so fustrated
Old Jul 25, 2009 | 10:29 PM
SmallBucket's Avatar
Perfectionist
Originally Posted by benzboy429
Hi All,
I have a cruzer also, I ended up doing a quick format (fat) and it did the trick. Make sure you don't put them into a seperate directory, only in the root.
Old Jul 26, 2009 | 09:25 AM
benzboy429's Avatar
when you say put them in a separate directory only in a root, what do you mean? Directly onto the drive, not in a folder?
Old Jul 26, 2009 | 09:56 AM
Perfectionist
Yes, they must be in the root directory and not in a seperate folder (like directly on your C drive in a PC).
Old Jul 26, 2009 | 10:20 AM
09tlsteve's Avatar
I had the same issue. Seem the sticks that had pre-loaded software (in my case the 'U3' auto-run junk) don't work. They should with a format as noted above, but I just used a different stick and it worked fine.
Old Jul 26, 2009 | 09:05 PM
str8aero's Avatar
I have no idea why it would make a difference, but I have had better luck with some memory sticks than with others. Also, it seems that if you have one picture of a group that the system doesn't like it won't recognize any of them.
Try a memory stick (FAT32) with nothing else on it and a picture from this site (there is a thread here with uploaded wallpaper jpg-s) in the root directory. Once you get it to work add other pictures.
Old Jul 26, 2009 | 09:36 PM
benzboy429's Avatar
OK so i formatted to FAT (not FAT32) put directly into the zip drive and now i got a new message....."USB device is disconnected. Returning to wallpaper setup"
Old Jul 26, 2009 | 09:39 PM
benzboy429's Avatar
hey steve, yeah i formatted and the U3 stuff doesn't come up anymore, so I'm good in that field
Old Jul 27, 2009 | 07:58 PM
benzboy429's Avatar
anyone? LOL
Old Jul 27, 2009 | 08:22 PM
NoelMarley's Avatar
I was having the same problem. I erased the U3 Launch File on the drive and it worked. Followed all the instructions in this post. Don't know what formatting is nor did I do that. Just saved off of the other post and dropped them on the USB drive. Good Luck.
Old Jul 28, 2009 | 12:47 AM
09tlsteve's Avatar
It's not worth taking too much time screwing with your memory stick -- just dig up one of those old 512 MB sticks from 5 years ago and it should work just fine. Drop the pics in the root. You only do this once ina while, so you can still use the 4GB stick for your day-to-day music.
Old Sep 26, 2009 | 09:54 PM
snowmanTL's Avatar
snowmanTL
I'm having the same problem. I tried two different sticks a PNY16gb and a Cruzer 2gb. The Nav keeps saying no files detected...
Old Sep 27, 2009 | 12:14 PM
Spring-Mike's Avatar
4th Gear
This has helped a bunch of people from my dealership.
Old Sep 27, 2009 | 04:06 PM
benzboy429's Avatar
when you format you select fat system and quick format, but what do you select for allocation unit size? it automatically selects an amount, should i be changing that?
navtool.com
Sponsored Sales & Group Buys
87
Jan 23, 2016 01:25 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
