Entering a passcode through Bluetooth?
Old Aug 24, 2013 | 07:58 PM
skasap's Avatar
6th Gear
Question Entering a passcode through Bluetooth?
I just upgraded from an 02 TL to a 2012 TL...When I drive with bluetooth I can dial a number fine. Question is I need to enter a numeric passcode for some conference numbers. Is there a way to do this? Thank.
Old Aug 24, 2013 | 09:03 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
On the 3G TL you could do this as follows -
To send a number during a call:
Press and release the Talk button.
After the beep, say ‘‘Send.’’ The
HFL response is, ‘‘What name or
number would you like to send?’’
After the beep, say the number
you want to send. For example,
say ‘‘1, 2, 3.’’ TheHFL response is
‘‘1, 2, 3. Say send, or continue to
add numbers
To send a pound (#), say
‘‘pound.’’ To send a star (*), say ‘‘star.’’
dial tones will be sent, and the call
will continue.
Not sure if the 4G is exactly the same, but would expect it to be somewhat similar. Give it a try and see what happens.
Old Aug 24, 2013 | 11:01 PM
bmode's Avatar
Once you commence your phone call, the screen should change and have 5-6 selectable tabs, then I manually select dial tones using the "wheel" to enter an extension number of the person I just dialed.
MetalGearTypeS
Aug 29, 2016 08:28 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
SUPRMN84
Oct 7, 2015 09:46 PM
TL14
Sep 24, 2015 04:37 PM
