Control GPS Volume?
Old 10-04-2011, 12:39 PM
nhester's Avatar
Control GPS Volume?
The spoken GPS instructions (e.g. "turn right at the next") are much too loud. I cannot figure out how to reduce the volume.
Old 10-04-2011, 12:43 PM
EazyRider562's Avatar
You cant is the thing....
Old 10-04-2011, 12:58 PM
potmilkz's Avatar
Received 1,021 Likes on 793 Posts
eazy, you havent had much time with the navi huh.. you will learn how to figure out things as you go along..
but to answer nhester question.
you have to go to menu and turn off the voice thing.
i turned mines to lowest so you can just barely notice it but enough to have you turn your head to the screen.
it should be under menu - slide right on the navi knob to go to settings..
nhester (10-04-2011)
Old 10-04-2011, 01:43 PM
omaralt's Avatar
just go to setup and lower the volume. i have it at the second lowest setting and it's perfect for me
Old 10-04-2011, 02:06 PM
nhester's Avatar
Thanks. I think I have tried this with no luck... but will try again.
Old 10-04-2011, 03:21 PM
Even on 2009 though?
Old 10-04-2011, 03:26 PM
potmilkz's Avatar
i have a 2010, and i have the ability to lower it, so you should have the same as well..
Old 10-04-2011, 03:29 PM
do you have any mods?
Old 10-04-2011, 04:09 PM
potmilkz's Avatar
not on the stereo or navi at all..
Old 10-04-2011, 05:17 PM
mightl's Avatar
I think this is good for 2010 and beyond... not sure about 2009.
INFO > SETUP > VOLUMN
Old 10-04-2011, 05:36 PM
i dont think you can do it on 2009
Old 07-06-2012, 02:57 PM
5th Gear
BlackAcTL09's Avatar
I have a 2009 and that worked for me!
Old 07-29-2012, 10:12 AM
7th Gear
txhogfan94's Avatar
Worked on my 2012.
Old 07-30-2012, 02:16 PM
Thermoguy's Avatar
You can turn the volume off by just going Info > Setup > Volume > OFF.
No sound with GPS instructions - great that it doesn't cut in to music, but I have missed a turn or 2...
Old 08-01-2012, 05:51 AM
Don1's Avatar
Page 93 of the manual. In System Setup.
The navigation voice volume has 11
settings and can be adjusted by:
• Using the voice control system and
saying “Volume up” or “Volume
down.”
• Selecting Volume and changing the
setting by rotating the Interface
Dial knob.
• Saying “Volume Off,” or selecting
Volume and then OFF.
Old 08-05-2012, 09:31 PM
thegreekulak's Avatar
Thanks! I was looking for this as well
knight rider
03-04-2016 08:59 AM
blacktsxwagon
10-27-2015 10:12 PM
adreano17
09-29-2015 08:48 AM
CWOVette
1/2G MDX (2001-2013)
09-27-2015 02:29 AM
4drviper
09-23-2015 09:00 PM
Quick Reply: Control GPS Volume?
