Big 3 Questions
Old May 23, 2016 | 09:57 AM
mossman77's Avatar
Big 3 Questions
I ran the 4 AWG power wire for my amp this weekend and would like to at least upgrade the battery-to-chassis ground wire. I guess you would call this a Big 1 upgrade . Would 2 AWG suffice or should I run 0 AWG? And I don't have crimpers to crimp that large of connector, so what do you guys think of the KnuKoncepts 0 AWG screw terminals?
Amazon.com: KnuKonceptz 0 Gauge Set Screw Ring Terminal Pair: Car Electronics Amazon.com: KnuKonceptz 0 Gauge Set Screw Ring Terminal Pair: Car Electronics
Old May 23, 2016 | 10:00 AM
i think you're over thinking things!
any wire that is larger than stock would be an "upgrade" whether it be 2 AWG or 0...
and any terminals that give a secure connection would work.
Old May 23, 2016 | 10:05 AM
mossman77's Avatar
Yes, I do over think things. It's in my nature.
What I meant is that my amp specifies 4 AWG minimum so I'd want to increase the size of the battery-to-chassis ground wire by at least that much. Think I'll go with 2 AWG since I'm not drawing an awful lot of current anyway.
Those connectors got good reviews, although some complained that they aren't long enough and you can't get a good sized bolt on there.
Old May 23, 2016 | 10:29 AM
I have those terminals and they work fine for me..
Old May 23, 2016 | 10:30 AM
mossman77's Avatar
Hmm okay. Here is another set that appear to have more clearance...
Amazon.com: Rockford 1/0 Awg Set Screw Ring: Car Electronics Amazon.com: Rockford 1/0 Awg Set Screw Ring: Car Electronics
Old May 23, 2016 | 11:09 AM
mossman77's Avatar
I suppose I could just add a second ground wire in parallel and leave the factory ground in place. That would be easiest.
Old May 23, 2016 | 11:20 AM
Old May 23, 2016 | 11:27 AM
using the noggin'!!!!
Old May 23, 2016 | 02:59 PM
mossman77's Avatar
...although one foot of 16 AWG copper stranded wire has the same resistance as 17 feet of 4 AWG wire, so I could probably just remove the factory ground and be just fine with a 12" length of 4 AWG. Makes me wonder why people do the Big 3 with 1/0 AWG. Seems way overkill.
CzEcHy_6MT3G
Sep 7, 2020 09:01 PM
Ac Attack
3G TL Photograph Gallery
53
Oct 28, 2016 10:10 AM
Enrick Gatien
Apr 3, 2016 10:26 AM
prepreludesh
Mar 16, 2016 12:25 PM
