Apple iOS 5 - Doesn't work with the Acura
Old Oct 22, 2011 | 12:58 PM
MatthewMccann's Avatar
Hello -
Have an iPhone 4, and recently upgraded to iOS5 and I can confirm that it no longer works with the Acura TL 2009. You can still charge the iPhone but you can not control the iPod integration via the radio. I had my car in for service and they said Acura has never released an update to fix any issues. So, I guess we are just stuck with the "Technology" that is built into the car. Beware if you are buying a new model as iOS5 is not supported.
I can still use Bluetooth for phone calls, etc... But the actual control via the USB port is gone.
Acura really needs to get an update out to fix this and some of the other bugs in the system.
Old Oct 22, 2011 | 01:51 PM
eluzion's Avatar
I have a 2011 TL and my iPhone 4 with iOS5 works okay. The only issue I'm having is it will no longer play through a playlist in order. It seems to reorganize my playlist every time I choose a song within that playlist. This probably doesn't make any sense and that's because, well, it doesn't make any sense to me either.
For those wondering, the new iOS5 is suppose to send track information via Bluetooth but the TL doesn't seem to display track information from Bluetooth (at least not in the 2011).
Old Oct 22, 2011 | 01:54 PM
PaulNY's Avatar
Is your iphone/car set to random/shuffle? It's in the audio options in the car..
My iPhone 4 and 4S both work fine with USB controls and BT audio
Oh, and BT track info is only available for the 2012 TL, not the '09-11
Old Oct 22, 2011 | 02:05 PM
omaralt's Avatar
Mine works. However the first time I plug the iPhone in I see no songs and it doesn't work. I have to unplug it and replug it and then it works. Otherwise works just like before
Old Oct 23, 2011 | 03:56 PM
eluzion's Avatar
Yeah, I have shuffle off. Figures the 2012 has the BT track info but not the 2011. I bet they could release a software update for it to work on the 2011 but that will probably never happen.
Old Oct 23, 2011 | 08:26 PM
sarge_in's Avatar
If it's any consolation, the 2012 does not display the info from iPhone 4 as well due to iPhone BT impementation. Bummer! In case anyone has it working with iPhone, would be good to know!
Old Oct 23, 2011 | 10:57 PM
eluzion's Avatar
Ah, must only be an iPhone 4S thing then? Either way, I wish the 2011 TL supported it since I intend to upgrade to the 4S or 5 (whenever that may be).
Also, my playlists are working fine now. I don't know what the deal was. So the iPhone 4 with iOS 5 is working normal in the 2011 TL.
Old Oct 24, 2011 | 05:06 AM
illmaticskillz's Avatar
IOS5 works with the 2012
Old Oct 24, 2011 | 10:52 AM
sarge_in's Avatar
I doubt the 4S shows the bluetooth info either.
I agree it would be nice to at least have the feature updated in 2011 if possible.
Old Oct 25, 2011 | 12:44 PM
cnims's Avatar
Does anyone know if you get the 2012 Navigation DVD update if it will add the ability to see the tag information over BT on IOS 5?
Old Oct 26, 2011 | 11:53 AM
dwest1023's Avatar
I have Iphone4 with OS5 and no issues with my 09 TL, everything works as before. I also have no issues with my ipod nano I just got and upgraded OS.
Old Oct 27, 2011 | 03:06 PM
catnippants's Avatar
Have any of you guys noticed this?
https://acurazine.com/forums/1g-rdx-audio-bluetooth-electronics-navigation-159/hfl-signal-strength-meter-iphone-4s-836637/
I'm wondering if it's an RDX (or me) only issue...
Mike
Old Oct 29, 2011 | 11:54 AM
jabrah's Avatar
MD // NYC
i have a 2010 TL, iphone4/BT and 3GS/plugged in on IOS5 and both work with no issues
Old Nov 18, 2011 | 11:57 AM
bailstew's Avatar
ipod nano problem with advanced awd tl 2012
2012 tl advanced worked for two weeks with my ipod nano and now no sound comes out even though it shows all songs on screen. Sound OK with hdd, xms, etc but not with nano. Dealer is stumped. I upgraded, rebooted nano with no luck....any help?
Old Nov 18, 2011 | 12:22 PM
Redstorm's Avatar
Have you tried any USB flash drive instead of the the nano? It may be that the USB plug/interface has gone bad.
Old Nov 18, 2011 | 12:25 PM
dwest1023's Avatar
I have ipod nano(latest version) and there is no issue at all. Works in all 3 of my vehicles.
Old Nov 21, 2011 | 07:42 AM
TLsMD's Avatar
WINNING
Also have 2010 ios5 works here ipod touch
Old Dec 5, 2011 | 04:30 PM
llangley's Avatar
LMLINNO
My 2010 seems to forget that i listened to my ipod under my playlist. Seems like once a week i can plug my iPod touch in and i have to reset the audio options to shuffle songs and play from a particular playlist. I also hear a static/popping noise when i play thorugh the USB. I am convinced it is an Acura glitch in my car but none of the dealerships agree with me so i guess i have to deal with it
Old Jun 11, 2012 | 07:22 PM
Libby's Avatar
I also have a 2012 TL and my iPod Nano worked for approximately one month and now no sound comes out, too. My dealer is also stumped. Can anyone help? It seemed to quit about the same time that the free XM radio subscription ended. Could this have anything to do with it? Nano is totally upgraded and I also rebooted, but still no sound.
Old Jun 11, 2012 | 07:39 PM
billyt1963's Avatar
Libby - From your message it sounds as if you are connecting with the iPod connector. Right? Which version of Nano are you using? I would suggest trying an audio cable just to see if that works. I have a couple of Nanos and am willing to try some things if I have the right version.
tonio
Feb 5, 2019 05:43 PM
Rocktman1
Oct 31, 2015 02:33 PM
usdmJON
Sep 4, 2015 12:59 AM
NSolace
Sep 3, 2015 08:02 PM
dlknight
Sep 3, 2015 07:54 PM
