Aftermarket Sub
Aftermarket Sub
Has anyone hooked up an aftermarket sub to a tech package? Can you pull the signal off of the stock sub?
Probably still have to run a power and remote wire and disconnect the stock sub?
Any insight would be great!
Thanks!
Colin
Thanks!
Colin
I have replaced the stock sub with two 10" rockford's and punch amp to run the sub. They just ran the HI/Low converter in the rear deck and it sounds great I couldnt stand the distortion on factory at the high volumes other than that i think factory is good system i will probably replace all speakers at some point but for now its good. Im just waiting for nav tool to be plug and play for the video.
They took the sub output and hooked up the HI/Low from there. Yes i can control sub output from deck , but i also got a bass know to make minor adjustments outside of deck works great
that's fantastic news!
If you're just using a hi/low pass converter, but still pulling from the deck, I'm curious, does the sub get consistently louder the higher you turn the volume? Or does it scale it back a little when you turn the volume all the way up?
Sorry, I didn't understand the last part though:
i bought a hi low converter for like 25 bucks. i had to cut the audio cables to the stock sub. but i left room so if i want to reconnect it i have enough wire to reconnect it.
i ran the cables that normally go to the stock sub to the high low convert that converts it to a low level rca connection. connected that to a 1000 watt alpine amp to 2 jw3 subs.
and you still get to use the sub control which is cool. i left the stock sub in the whole, i didnt want to have to remove it.
when you turn up the volume it turns up the aftermarket sub with it. you can also adjust the hi low converter to tweak it to how much bass you like.
i think if you put an aftermarket speaker to the stock amp, its not going to sound much better.
kb1rl
09-30-2015 10:17 AM
xsilverhawkx
09-28-2015 06:51 PM
