2009 stock amp wire identification
Old Apr 25, 2014 | 10:59 AM
Gbaker332's Avatar
4th Gear
What’s up people. I am in need of some good technical support. I know there are many post about the audio systems but I have been unable to find the information I need. I am install new speakers and I am splicing the wires coming out of the AMP and running them into audio control LC7i. It will convert the high level input into low level inputs. From there the RAC’s will go to my APMs. The problem I have run into is that I am using the 2010 maintenance manual and it does not seem to match my vehicles wiring. I have been unable to find the manual for the 2009. I have the 09 AWD with Nav/tech package.
The first set of pictures is schematic 1 and 2. One these schematics there are 2 wire colors that are different so I am unsure which one is correct.
Schematic 1
Schematic 2
Positive
Negative
Positive
Negative
Front Left Door
Gray
Blue
Lt Green
Blue
Front Right Door
Gray
Brown
Gray
Brown
Rear Left
Yellow
green
Yellow
Blue
Rear Right
Blue
yellow
Blue
Yellow
The second issue is that schematic 2 and the vehicle wire colors/positions do not match. Again this might be because I am using the 2010 schematics. But here is the list.
Schematic Pin Bottom Row
AMP Connector Bottom Row
White
White
Yellow
Brown
Lt Green
Brown
Gray
Red
14
Blue
Blue
15
Red
Gray
Brown
Lt Green
17
Brown
Yellow
18
Gray
It appears that they are simply inverted with the exception of pin 10. Again there is no way to know for sure without the 2009 schematics.
I need specifics or the schematic from the 2009 if anyone has them. I know that I can work all this out with a multi meter but I choose to work alone which makes it difficult. I could really use some solid info if anyone out there has it.
Old Apr 25, 2014 | 11:01 AM
Gbaker332's Avatar
4th Gear
Schematic 1 PostitiveNegativeFront Left DoorGreyBlue Fornt Right DoorGreayBrownRear LeftYellowgreen Rear RightBlueyellow
Old Apr 25, 2014 | 11:08 AM
Gbaker332's Avatar
4th Gear
sorry these tables got all messed up.
Shematic 1
front left door +Gray -Blue
front right door +gray -Blue
Rear left +yellow -green
Rear right +Blue -yellow
Schematic 2
front left door +Lt Green -Blue
front right door +gray -Brown
Rear left +yellow -blue
schematic pins and actual connector colors
10. White White
11. Yellow Brown
12. Lt Green Brown
13. Gray Red
14. Blue Blue
15. Red Gray
16. Brown Lt Green
17. Brown Yellow
Old Apr 25, 2014 | 11:14 AM
Gbaker332's Avatar
4th Gear
My work computer messed this all up....
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
pistacio
Sep 26, 2015 09:45 AM
yahelou
Sep 6, 2015 09:12 PM
