2009 Base Compass Problem
Old Nov 26, 2012 | 07:41 PM
IronChicken's Avatar
2013 TL SH-AWD Tech (BWP)
Anyone had an issue with their compass on a base model? I disconnected the battery for a couple of days to remove the pillars (didn't want to take chances triggering a bag while crushing the crush clips which never actually crushed btw - what a pia) and ever since my compass is blinking and not calibrating. It's not displaying CAL, just blinking and not usually correct. Worked perfect before disconnecting the battery. I've tried the manual's procedure, but never get a CAL like it says will/should appear. The manual also says to put the key in position II, but never to start the car, but then to drive it slowly in circles, which I'm not sure how you could do without starting the car (unless you're on a really steep hill ) so that's a bit confusing. I also cannot change the zone from 8 like it says (I'm in 7) - the MFD "wheel" moves on the left, but it never changes from 8. Any trick to this? Do I have to disconnect the battery again or something? I didn't care about it for months, but now it's bothering me for some reason... I've tried about everything I can think of to no avail. No magnetic stuff around or anything. I saw CAL show up once but the car wasn't started, then of course when I started the car, CAL disappeared. Ugh.
Old Dec 9, 2012 | 03:17 AM
Apparently the compass "box" is on the back deck near the sub and replacing the sub with one with a much larger magnet is throwing it off.
Old Jul 29, 2022 | 07:16 AM
Frankyy's Avatar
2014 TL
hi I notices a really old post but my 2014 TL base is having the same issue my compass is blinking when I started it this morning I can’t get it to fix itself
I seen a few posts mentioning about zones what is that? Because I don’t see anything with zones on my car
thxs in advance
almyers05
Jul 5, 2024 06:43 AM
fbt
Nov 19, 2018 03:19 PM
mrcombs
Nov 23, 2009 01:29 PM
daoism76
Jun 3, 2009 01:45 PM
