V-LEDS Switchbacks
Old Feb 17, 2011 | 09:33 AM
cybersonic's Avatar
V-LEDS Switchbacks
I did a search regarding switchbacks and there are many mix statement of it being good and bad. I currently have a pair with load resistors right now but contemplating if I should move forward with the installation or call it a lost and send it back. This is what I got so far from people:
· Good - im pretty sure that the resistors only heat up when you have the signal/hazard lights on for a long time. there is no need to have a resistor for the running lights so you should be ok.
· Good - I mounted my resistors on the firewall I believe. I spliced into the wiring harness as close to the fire wall as possible in order to reduce the chance of road debris, water etc from getting to my connections. I spliced, soldered and heat shrank my connections for maximum protection etc
· Bad - Before the switchbacks, I had already done the door, reverse and center console and glove box lights to LED. Those I didn't have any issues. I also have blacked/cleared out headlights with LEDs in the corner markers and LEDs for the fogs. Those were done before the switchbacks. After the issues I had, I ONLY pulled out the switch backs, and that was the ONLY problem I had. All the other bulbs that I changed I left in as LEDs, and I haven't had ANY problems since then. I am probably just going to leave the amber turn signals in there. I think those are the ones I bought, and honestly, like I said, I'm not going to try again. It really freaked me out and thought it would cost so much more to repair, but I would rather not have to spend that again. Oh, and I also have LED strips installed by the headlights, none of these other things have caused ANY problems at all.
Please tell me your experience if you have switchbacks. What brand and model you have, if you have resistors, how long you had them on, and if it’s good or bad. If there are any problems after you installed the switchbacks, please indicate what the issues are. Below is what I have. Thanks guys.
V-LEDS TYPE 2 DUAL COLOR CHANGING 6K WHITE AMBER SWITCHBACK 60 M-SMT TURN SIGNAL BULBS 1157 2057
http://www.v-leds.com/Exterior-LED/T...-p5851397.html
6 OHM 50W 2 BULB LED LOAD EQUALIZER RESISTORS TURN SIGNAL BLINKER FIX WITH MOUNTING PLATES
http://www.v-leds.com/BlinkerWarning...26800-1-2.html
Old Feb 17, 2011 | 10:01 AM
Derk's K24's Avatar
is in Honda heaven
Am I missing something? Did you state what issues you actually had rather than just saying you had "issues"?
Old Feb 17, 2011 | 10:30 AM
cybersonic's Avatar
If there are any problems after you installed the switchbacks, please indicate what the issues are’
Meaning, if there were any issues after the installation.
Old Feb 17, 2011 | 11:29 AM
potmilkz's Avatar
some people have issues, some dont, it really depends on how the installation goes.
what i suggest is to disconnect battery before doing anything
Old Feb 17, 2011 | 11:39 AM
cybersonic's Avatar
Some people have stated that there were no issue, but down the line they encountered electrical issues. All I know for sure is that most people agree that the resistors get very hot, so hot that it may melt the wires. Now the million dollar question is, will the resistors get hot when the lights are on constantly or when the signal is in use?
Old Feb 17, 2011 | 12:07 PM
potmilkz's Avatar
resistors get hot only when use.
if you use it on your front lower turn signals ( since its a 2 way ) then most likely it will get hot with a 6ohm..
i suggest a 33ohm resistor. ive heard they do not get hot and works the same way.
Old Feb 18, 2011 | 02:25 AM
Yardinc's Avatar
Installed the 92 SMT without any issues. Order the resistors with the heat sink if you are concern about the heat.
Old Feb 20, 2011 | 03:10 PM
midnite_tl's Avatar
I looked all over v-leds.com and cant find a 33 ohm resistor to save my life, did you mean to say 3 ohm, maybe? Just spitballin, otherwise, where can I find a 33ohm resistor?
Old Feb 21, 2011 | 10:42 AM
potmilkz's Avatar
you cant find it at vleds.
you have to find it at like some hardware store.. try radioshack..
you just need something higher than 12ohms
TLrascal
Aug 3, 2018 11:00 PM
baowheezy
Sep 22, 2015 09:03 PM
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
mista.huynh
Nov 1, 2008 03:01 AM
RA082925
Dec 10, 2007 08:18 PM
