switchback help on 4g
Old Sep 6, 2015 | 09:18 AM
baowheezy's Avatar
Hey guys ive reading the forums and I can only find help from 09-11 or 2 I believe but I can find anything on 13+. Would it be better to get switchback or led lights? Thanks guys.
Old Sep 6, 2015 | 10:15 AM
TheMuffinMan's Avatar
You mean for the front driving/parking lights and turn signals?
The default behavior is going to be a switchback that's white and amber.
The bulb is a 3457A, however in LED land I believe that is interchangeable with 3157, such as this bad boy:
V3 TRITON GEN 2.5 WHITE AMBER LED SWITCHBACK SYSTEM 3157 | 1 SET
Which is an LED switchback, your question is kinda confusing.
Old Sep 6, 2015 | 08:14 PM
baowheezy's Avatar
hey muffin this is exactly what i've been looking for thanks! do you recommend the Optional Resistor (2),Base Adapter Waterproofing, and Resistor Mounting Tape (2)?
Old Sep 6, 2015 | 11:01 PM
I actually personally don't have that set, so I can't tell you 100% if those things are worth it. Quite a few guys on AZ have VLED products (myself included) so I'm sure there's a few that can answer your question. Probably best to ask in the Electronics section and/or search to see if someone's already done it.
Old Sep 7, 2015 | 12:41 PM
Jerry"O"'s Avatar
Just get the vleds!!! Check this thread on 2012-2014TL.
https://acurazine.com/forums/fourth-...-vleds-916632/
Old Sep 7, 2015 | 08:54 PM
BDoggPrelude's Avatar
I also have the V-LED Triton V3's and love them. Great output. Great build quality. Like Jerry "O", I have the Gen 2.0 that came with all of the resistors and such inside of the control boxes so I can't advise you on which optional pieces you need for the install.
Here are the 5k Triton swtichbacks along with Morimoto XB LED Fogs, (another great item for 12-14 TL's). Jerry has the exact same setup.
Attachment 102701
Old Sep 8, 2015 | 06:55 PM
cp87's Avatar
6th Gear
BDogg, what are you running for DRL?
Old Sep 8, 2015 | 10:12 PM
V-LED's MT-G2 3200LM LED kit. They don't make them anymore. They've been replaced with the LMZ kits that are not as DRL/high-beam friendly as the old ones from what I've heard.
Old Sep 9, 2015 | 11:23 AM
ere4mado's Avatar
BDogg - does the V-LED's MT-G2 allow for the lower vs. higher output (meaning you don't loose the DRL vs. High Beam functionality)?
Old Sep 10, 2015 | 02:23 PM
Yes.
Old Sep 19, 2015 | 05:31 AM
SlyAccord's Avatar
Yes, yes, yes, and yes. Get all that. You need to mount the resistors and the tape they provide is great, I mounted mine to the bottom of the frame as they recommended. Overall order from them, you won't be disappointed. Once you have the order, give them a call for your questions, they're VERY nice and very helpful.
Old Sep 22, 2015 | 02:24 PM
baowheezy's Avatar
Hey Jerry are these plug and play it would you have to cut weird?
Old Sep 22, 2015 | 09:03 PM
Plug and play.
TLrascal
Aug 3, 2018 11:00 PM
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
manolo
Jun 4, 2009 08:16 AM
GoldnKnight22
Sep 29, 2008 07:50 AM
Fulani has a TL
May 8, 2008 09:18 PM
