revometer question
Old Dec 15, 2009 | 04:56 PM
bleechme13's Avatar
revometer question
sorry if this is a noob question and im not sure what its called exactly but, my revometer sits at 1 when the car is off. is it suppose to be like that or is it suppose to be at zero?
Old Dec 15, 2009 | 06:21 PM
BLACKURA_NY's Avatar
I have car ADD
do you mean tachometer? (Thats the engine speed.. it goes from like 0 -8, and turns red around 6.700)
If so, yes, when the car is off... it should be at 0
Old Dec 15, 2009 | 06:37 PM
bleechme13's Avatar
yes the tachometer. lol that shows the rpms.
how about when u brake at a red light? should it be at zero?
Old Dec 15, 2009 | 06:52 PM
jspagna1's Avatar
The Sicilian
If car is on the tach will not be at zero. It will be at a very low RPM....
Old Dec 15, 2009 | 07:06 PM
N7Titan's Avatar
you know i like intuitive names, lol.
but yes if the engine is completely off it should be at 0
if it is on it should not be at 0
Old Dec 16, 2009 | 12:19 AM
I have car ADD
When the engine is idling, you should be at about 750 rpm (just under 1k)
it will jiggle a little while the engine is running, and it will sometimes dip down to 600rpm when the compressor kicks on every 1 minute or so
Old Dec 16, 2009 | 08:04 AM
Kingmeow's Avatar
Also it might a bit higher when the engine is just started in the cold during the winter. Once warmed up the RPM will drop back down to the 750 mark mentioned above.
Old Dec 16, 2009 | 06:10 PM
big1128z's Avatar
Ok. You tachometer should NOT be at 1000 rpm when you turn the engine off. Do you have any further symptoms other than the tach does not go down to 0? What kind of car do you have, year, make. Your in a 4G TL forum so I will assume that you own one. Correct me later if I am wrong. The manufacturer ships the unit with two fuses removed under the hood to conserve battery power when shipping. Dealer puts the fuses back in during dealer prep. If the fuses are still not installed by the dealer you will have a heck of alot of issues with either the interior lighting since that is one of the fuses. The other fuse goes to the combi meter (the part with the revometer in it) and the audio unit and HVAC ECU. Put the car in accessory 1 positon. If nothing lights up on the HVAC or audio LCD screens the fuses are still missing from thier slots.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
