Post instructions to remove front bumper
Old Oct 21, 2010 | 10:17 PM
apdspider's Avatar
I need to install new HID low bulbs.
I cannot find instructions on how to remove the front bumper.
Can someone please post a link.
Thanks.
Old Oct 22, 2010 | 12:06 AM
FallenTSX's Avatar
1)six bolts underneath bumper and 2 snap screws
2)1 screw and 2 snap screws near front wheel wells (Drive and Passenger sides)
3)4 bolts holding the shield in the engine bay
then off it goes, you'll have to pry a little to take it off, but it will come off
Then...
4) 2 bolts on top holding headlights (Drive and Passenger side)
6) 2 bolts holding the assembly underneath the headlights, one right in the front and the other near the outboard side (Driver and Passenger side)
That's it...I will try to look for the actual Acura manual thingy, but don't have it saved on this computer
Good Luck!
-DeL
Old Oct 22, 2010 | 12:26 AM
GunnerX's Avatar
Instructions with pictures.
http://acura.bernardiparts.com/Image...r_BII42529.pdf
Old Oct 22, 2010 | 11:41 AM
apdspider's Avatar
Thanks guys... this is exactly what I needed.
Old Oct 22, 2010 | 12:04 PM
mdx_tl's Avatar
One thing you need to be very careful when pull the front bumper out from the body (step 9 and step 10). DO NOT pull it too far from the body until all the connectors are unplugged. I almost broke them when I removed the front bumper to put the sport chrome grille in. Beside of that, it's not too hard. You can get it off the body in 30 min.
Old Nov 7, 2010 | 09:13 PM
DrOmar's Avatar
9th Gear
Is there no way to change the hid bulbs without removing the bumper? Why is it so difficult to change a freakin bulb
Old Nov 8, 2010 | 02:20 AM
GunnerX's Avatar
I'm guessing you didn't have any luck going through the wheel well area?
Old Nov 8, 2010 | 08:13 AM
Pete2010's Avatar
Why take off the bumper? In the owners manual it will tell you how to replace the HID's. Simply go in thru the wheelwell. I did that to swap my sidemarkers with LED's and it took me about 10min total.
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
leerbgdup
Sep 6, 2015 11:01 PM
Sixers12
ILX
Sep 6, 2015 07:54 PM
robowarrio
Sep 1, 2015 09:25 PM
