Oil leakage
Old Sep 23, 2025 | 06:30 AM
rztlowner's Avatar
8th Gear
Oil leakage
i was doing 3x transmission oil change. (2013 Acura TL SH-AWD, has 155K miles).
At the first oil change I noticed the oil leak and cleaned it up with break parts cleaner like pic 1.
At the second oil change after a week of driving I noticed the leakage again like pic 2.
is this a simple matter of replacing washers on 3 bolts with arrows?
Thank you,
PS: Picutre upload is not working here. (It stops at 90%)
It’s the 3 bolts above transmission oil drain. Two large and one small below black cover.
Old Sep 23, 2025 | 08:45 AM
Thank you,
Yeah, we are going to kind of need pictures to assess the area in question?
If I'm not mistaken, #17 below is the ATF drain bolt (torque converter housing)?
Use the link below to navigate parts diagrams for your TL.
AT Torque Converter Case - 2013 Acura TL 4 Door ADV (SHAWD) KA 6AT
This diagram displays the trans. housing & #11 is the ATF fill bolt. do you see any of the 'bolts' you are referring to??
Cooldude01
4G TL Problems & Fixes
Apr 7, 2016 09:56 PM
George Knighton
3G RLX (2013+)
Oct 5, 2014 01:59 PM
cabanalane
Sep 30, 2014 09:32 AM
mav238
1G RDX (2007-2012)
Nov 19, 2007 09:46 PM
NavyDoc333
Nov 2, 2006 04:59 PM
