OEM aero kit fitment/wheel wells
I installed the aero kit and I was wondering if the wheel well trim is suppose to go over the screws or under?
- For the rear I manage to screw the wheel well trim over the lip but the side skirt and front lip doesn't look like it would work. For the front, there's a screw but it doesn't seem to screw into anything because there is no hole on the wells if it goes over it.. I have a few pictures below..
What did you guys do?
http://www.flickr.com/photos/1104669...n/photostream/
It does look weird but if you followed the DYI instructions per Acura then it should be correct. Seems like it's supposed to go under though.
^^ My bad. I didn't gather that information from his post so my apologies.
OP....disregard my message and photo.
it's been a split minute since I've done one but isn't that where the bracket goes?
6G TLX-S
What bracket ?
What bracket ?
I believe it's the rear has a metal bracket on both sides that you bolt to the Bodykit and that bracket bolts to the car where the old stuff bolts up...
The rear I have it screwed against the wheel well trim, but the fronts are weird. The upper most screw is not screwed into anything but the end of the screw is just against the wheel well trim..
Skirmich
09-15-2015 06:41 PM
