Misfire
Misfire
Hey guys, I have a misfire on cylinder 6, looking to troubleshoot it by first moving the coil to another cylinder to see if the problem follows, if so I will replace the coil.
However I am having an issue getting the coil wires shroud/cover off so that I can work on the coils (don't really know the name, if someone could let me know what its actually called, annotated image below).
I have been able to undo the two clips on the top and slid the "shroud" off however I am still unable to actually open it and remove it.
If the issue does not follow the coil or the plug, I assume you are up to date on your valve clearances? If not, I had a J35 in a V6 Accord that began to misfire at cold due to valves being out of spec. Worth checking out as another option.
Jason Deglman
2G CL Problems & Fixes
11-09-2016 01:12 PM
PITBULL
05-13-2008 10:04 AM
SatinSilverTypS
08-15-2005 09:47 AM
