I Have Found The Misfire Problem !!!!!!!!!!!!! People With Misfire Are Not Read!!!
As some of you already know I've been having misfire problems with my car for over a month now. I' ve been on a mission to solving my own problem without a mechanic,not for nothn but i just felt like it.If nobody has tried this method I suggest ya do. this is a website that i came across to help me with my prob. Now i got a new one how can i get the middle coil connector working keep in mind its not the coil but the wire all others do work i tried it using the method..
I wanna thank all the people who was giving me edvice
http://autorepair.about.com/od/troub...est-manual.htm
I notice people reading ^^^^ if anyone can tell me if there is way to fix the ignition wire that im talkn about let me know are else i'll have to talk to acura to see how much their charge if there's no way i can do it myself..I hope I dont have to get the whole wiring I did notice fsttyms1 got his wiring new how much was it ?
if there is a short or break in that specific wire the only thing you can do is replace it with a new one(wire), is it the plug/harness itself or the wire/pins that is causing the problem?
I pluged the coil into the wire harness itself like I did with the rest when I was testing them. I'M not sure weather is the inside of the connector itself or the whole wire. How far does the wire go I was thinking of checkn to see if theres a cut somewhere maybe?? or opening to connector itself to see if the is a good connection
well all you can do is trace that wire and look for breaks in it. Look in the connector itself and see if its corroded or not, and broken? The whole engine harness is like 350.
Received 1,080 Likes
Easiest way to tell if it's the wire is to swap the coil pack with another one and if you still don't get spark, it's the wire to the coil pack. You could obviously try a few of the coil packs if you suspect you have multiple bad coil packs.
I have 122,000 miles on my TL and I've only ever had to replace 1 coil pack. They seem to go a long time.
mada51589
05-03-2022 08:54 PM
