Keyless Entry
Old Mar 23, 2013 | 12:20 PM
cobra611's Avatar
Keyless Entry
Good afternoon,
The last several days, I have been unable to open my front doors ('09 TL SH-AWD) by just placing my hand on the door handle itself. Did I do something unknowingly that turned off this feature or perhaps I do have a real issue? This is happening on both the driver and passenger doors.
Thank you!
Old Mar 23, 2013 | 01:10 PM
TeamAcura's Avatar
Check the keyless settings in the MID screen to see what it's set to. This is where I would look at first.
Old Mar 23, 2013 | 01:11 PM
cobra611's Avatar
Thanks...I'll check as soon as I get out of work!
Old Mar 23, 2013 | 08:05 PM
sockpuppet's Avatar
I would check the battery in the remote, first. Try using the Driver 2 remote and see if you get different results.
Old Mar 24, 2013 | 02:10 AM
cobra611's Avatar
The batteries are fairly new and the light on the fob lights brightly when pressed. And yes, it does the same thing with the driver 1 key fob...I use #2 because it's not as scratched up. Not only do the doors not open when I grab the handle, it won't lock when I press the door button and I have to insert the key fob into the key slot to start the car. Very strange that this happened out of no where. Thank you for your help!
Back to Google....
Old Mar 24, 2013 | 02:19 AM
Edward'TLS's Avatar
6G TLX-S
Open your glove box and check if the "passive entry" switch is at "off".
If it is, switch it back to "on", and you should be ok.
Old Mar 26, 2013 | 12:27 AM
cobra611's Avatar
That's exactly what it was!!! I was fishing around in the there, looking for something, prior to all this happening. But, I never thought I came close enough to hitting the switch, but I guess I did. Thanks for all the replies!!!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
