Issue with guidelines for the rear view camera?
Old Jul 23, 2012 | 06:05 PM
dsm918's Avatar
Exclamation Issue with guidelines for the rear view camera?
Everytime I put the car in reverse, occasionally the yellow guidelines will not come on for the first few seconds. Sometimes it comes on instantaneously and other times it can take 2 to 4 seconds. Anyone else have this issue?
Old Jul 23, 2012 | 06:08 PM
KPSBUDS420's Avatar
Naw man, mine are always there right from the get go
Old Jul 23, 2012 | 06:26 PM
KGacura's Avatar
5th Gear
You are not alone, it happens on rare occasions for me also.
Old Jul 23, 2012 | 06:40 PM
A-10Wingman's Avatar
Same issue here. Maybe there is a delay because of the nav and radio starting up?
Old Jul 23, 2012 | 06:44 PM
sockpuppet's Avatar
I'm betting this is the case. OP didn't say, but I've seen the delay; it's always when I jumpo in the car and throw it in reverse without letting the system get up and running.
Old Jul 23, 2012 | 06:50 PM
stars_fan's Avatar
There was a service bulliten on this recently. I'm at work right now and looking it up on my phone isn't possible.
Old Jul 23, 2012 | 06:59 PM
FirstTL12's Avatar
Haven't noticed it in my June '12 build date TL Tech. But then again I usually always give the car at least 20 seconds warm up, and admittedly I don't look at the camera often. But when I do, the grid lines are always there. Good luck!
Old Jul 23, 2012 | 07:49 PM
dsm918's Avatar
Can you please post when you find it.
Old Jul 24, 2012 | 06:51 AM
i64X's Avatar
This. The navigation computer draws the lines, not the camera.
Old Jul 24, 2012 | 09:37 AM
RPhilMan1's Avatar
2024 Honda Civic Type R
Why do you put it into gear as soon as you start the car?
Old Jul 24, 2012 | 11:52 AM
vinnier6's Avatar
same here, and i bet everyone would have the delay if they started the car and threw it into reverse without letting the system get up and running....
Old Jul 24, 2012 | 01:33 PM
dsm918's Avatar
Other than the morning start or when the car has been sitting, I see no reason not to put it into gear after I start the car!
Old Jul 25, 2012 | 12:06 AM
Brian Ichi's Avatar
I also noticed this happens, but only when you shift into reverse directly from starting the car. I believe the CPU has to load just like a regular computer. This is also why you cant press OK to the "I wont blame Acura if i crash my car" screen at start up.
My solution was to just back up my car into spots and not need reverse while the computer. As far as I know Acura doesn't have a fix.
Old Jul 25, 2012 | 08:52 AM
RPhilMan1's Avatar
Well now maybe you do.
Old Jul 25, 2012 | 12:20 PM
jmkenn0's Avatar
Mine does it as well, and as others have stated, its the slow-a$$ bootup of the nav system. That's one of the few annoyances I have with the car; but the "warning" message prior to the bootup, and speed that up.
jspangan
ILX
19
Aug 30, 2016 05:37 PM
bymotion
Nov 18, 2015 11:28 AM
Rocktman1
Oct 31, 2015 02:33 PM
dre707
Sep 8, 2015 08:32 PM
KillerG
Sep 4, 2015 02:02 PM
