Issue with guidelines for the rear view camera?
Everytime I put the car in reverse, occasionally the yellow guidelines will not come on for the first few seconds. Sometimes it comes on instantaneously and other times it can take 2 to 4 seconds. Anyone else have this issue?
Haven't noticed it in my June '12 build date TL Tech. But then again I usually always give the car at least 20 seconds warm up, and admittedly I don't look at the camera often. But when I do, the grid lines are always there. Good luck!
same here, and i bet everyone would have the delay if they started the car and threw it into reverse without letting the system get up and running....
I also noticed this happens, but only when you shift into reverse directly from starting the car. I believe the CPU has to load just like a regular computer. This is also why you cant press OK to the "I wont blame Acura if i crash my car" screen at start up.
My solution was to just back up my car into spots and not need reverse while the computer. As far as I know Acura doesn't have a fix.
Mine does it as well, and as others have stated, its the slow-a$$ bootup of the nav system. That's one of the few annoyances I have with the car; but the "warning" message prior to the bootup, and speed that up.
dre707
Sep 8, 2015 08:32 PM
