How Much Power Is Lost When A/C Is Engaged?...
Old Aug 28, 2009 | 04:48 PM
PsychDoc's Avatar
I feel strongly both ways
I ask this because the car feels decidedly more sluggish when I have the A/C condensor "in the loop."
In terms of a 'seat of the pants' estimate of power loss, I'm going to guess that you lose about 15-20% of the car's optimal (read: A/C off) power.
That and the fact that the engine doesn't idle as buttery smooth as it does without the A/C in that loop.
Anyone have any more scientific info. on A/C induced losses?
Old Aug 28, 2009 | 06:35 PM
KeithL's Avatar
I don't think you loose 10-15% any more, I belevie at some point int he past the AC was a larger drag on the drive trains that it is today, I think they have boosted effieciencies and lowers power lose.
Old Aug 28, 2009 | 10:06 PM
CleanCL's Avatar
Normal cruising I'd say less than 10%, probably like 5% at best. At WOT (wide open throttle) the compressor shuts off and you lose no power.
Old Aug 28, 2009 | 10:33 PM
ll_22's Avatar
Is this a published function or widely known fact? Don't remember reading it in the manual.
Old Aug 28, 2009 | 10:46 PM
CleanCL's Avatar
Acura had done it on my 2001 CL, I know they also published it on the 2004 RL, I only assume they continue this function. I will try to find it.
Old Aug 29, 2009 | 01:41 PM
danimal1968's Avatar
It was that way on my first car - a 1984 Ford Tempo, so the concept of cutting out the compressor and the fan when the power is needed for acceleration isn't new.
Old Aug 29, 2009 | 05:28 PM
Eli's Avatar
Eli
They should use electric A/C compressors that aren't driven by the engine, like on some hybrids.
Old Aug 30, 2009 | 12:04 AM
VTEC Racer's Avatar
Honda Fanboy
I was always under the impression that the recent revision of HP figures (i.e. drop in numbers) now reflected what the HP output would be when the engine has the maximum amount of drain on it (including the A/C). So if I am right, then the TL should be making the advertised amount of power (280 or 305) with the A/C on and more than the advertised power with the A/C off.
Biggie_B
May 27, 2025 05:51 PM
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
joflewbyu2
Oct 8, 2015 11:16 AM
