High beam projector
I don't have a TL (yet), but the forums over at HIDplanet have tons and TONS of info if you're willing to look through it. I'm have retrofitted my current car with TRS/Morimoto Mini H1 6.0 projectors in the low beams.
i tried.. its too small of an area to put a projector inside.. you cant put a shroud around it and you are not able to put the lens back on.. your highbeam projector will stick out way to much.
only way to do it is the cut the back open meaning you cut a big hole to mount the projector further back.. also you will have to cut alot off a shroud to make it fit.
you will have fitment issues with your headlights later once you try to install them. Your headlight highbeam area sits right infront of your coolant reservoir and radiator, very limited space.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
