Front (or left) valve cover
Old Sep 29, 2025 | 07:01 PM
asb32952's Avatar
2013 tl sh awd 6mt calls for part # 12310-RKG-000 which is very expensive compared to part # 12310-R70-A10 (or A00).
When you read the descriptions for the first part # it states that it will fit both the 3.5 and 3.7.
Search Results | My Acura Parts
12310-RKG-000 Genuine Acura Front Cylinder Head Cover Assembly
RockAuto
Then go to the second part # and it says only 3.5 for the application.
Amazon.com: LEPOINT Aluminium Front Engine Valve Cover 12310-R70-A10 Fit 2008-2017 Honda Accord Odyssey Pilot Ridgeline Crosstour 2012-2015 TL RDX 3.5L : Automotive Amazon.com: LEPOINT Aluminium Front Engine Valve Cover 12310-R70-A10 Fit 2008-2017 Honda Accord Odyssey Pilot Ridgeline Crosstour 2012-2015 TL RDX 3.5L : Automotive
Amazon.com: Assembroverse Aluminum Front Engine Valve Cover 264-491 12310-R70-A00 12310-R70-A10 Compatible with Accord 2008-2012 Crosstour 2010-2012 Oddyssey 2008-2017 Ridgeline 2009-2014 TL RDX 3.5L : Automotive Amazon.com: Assembroverse Aluminum Front Engine Valve Cover 264-491 12310-R70-A00 12310-R70-A10 Compatible with Accord 2008-2012 Crosstour 2010-2012 Oddyssey 2008-2017 Ridgeline 2009-2014 TL RDX 3.5L : Automotive
If the first one says 6AT, 6MT, 3.5 and 3.7 for the same part #, how is the second one different but it still fits a 3.5?
Old Sep 29, 2025 | 09:35 PM
altair47's Avatar
RockAuto
What happened to the original?
Old Sep 29, 2025 | 10:28 PM
asb32952's Avatar
Shop said there is a hole in it. Probably why there is an oil leak.
Old Sep 30, 2025 | 01:55 PM
asb32952's Avatar
Update: part # 12310-R70-A10 (which was the cheaper one) fits on the 3.7.
Old Sep 30, 2025 | 02:33 PM
Just curious, how did you manage to get the confirmation?
Old Sep 30, 2025 | 04:46 PM
asb32952's Avatar
Repair shop installed it with no issues. Problem with the old one was that when replacing the spark plug tube seals, one of the old seals lifted out with a chunk of aluminum where it seats. It wasn't in a good position to just put some JB weld on it.
Deadlocked3545
Jun 29, 2025 10:03 AM
Poolman
May 19, 2023 04:26 PM
BlackTSX
May 25, 2004 08:41 AM
