Fluid
Old Jan 15, 2015 | 06:38 PM
ron3.7's Avatar
Fluid
Changing transmission fluid this weekend I need 2 crush washers one for the bottom drain hole one for the top fill hole question = the 2013 acura tl sh awd takes a little more than 3 1/2 it takes 3.75 yes or no.
Old Jan 15, 2015 | 09:46 PM
Reorge's Avatar
Spec is 3.3 quarts. I put 3.5
Old Jan 15, 2015 | 11:41 PM
Georgiey22's Avatar
I just completed this fluid change and added 3.5 quarts. Highly recommend Honda/Acura ATF only.
Old Jan 16, 2015 | 08:57 AM
ron3.7's Avatar
Yes
Ya im going to use Acura ATF only because of warranty but thats all I would use anyways.Thanks guys
Old Jan 18, 2015 | 12:57 AM
Georgiey22's Avatar
Just my two cents Ron3.7 however I personally don't replace the crush washer and fill the ATF through the dip stick tube...doesn't take much time at all and saves me from having to replace the washer. Whichever route you take we'd enjoy your thoughts on the shift changes after the new fluid goes in. How many miles do you run the oil before replacing? On a side note I got 10% my Honda fluid when I purchased an entire case.
Old Jan 18, 2015 | 04:39 PM
Reorge's Avatar
Majestic Honda web order has Honda DW-1 fluid for $5.56/qt. (List $8.30, 33% discount). Honda fluid (08200-9008) and Acura fluid (08200-9008A) are identical except for the label on the bottle.
Website: Majestic Honda - The Internet's #1 Honda Automotive Parts Store
A case of 12 is $66.72, no tax, $4.95 handling, and $13.26 shipping is $84.93/case ($7.08/qt). That's a ~15% discount, no tax, delivered to my front door. Some other Acura parts are also available to order if you know the part number (air filter, cabin filter, tranny filter, oil/tranny plug washers, fluids, etc) and they are used on other Honda vehicles. Therefore other maintenance parts can be ordered with only one handling charge per order.
I'm sure there are other websites but this is one I found with a good price. I have ordered from them before with no issues.
Old Jan 26, 2015 | 09:38 AM
vinnier6's Avatar
What mileage are you guys changing the transmission fluid
Old Jan 26, 2015 | 05:51 PM
csmeance's Avatar
I believe the book states at every 30K miles, I change it every other oil change after having the trans crap out in my 3G TL at 95K Miles with changes at 60K, then every 30K thereafter.
The fluid is cheap insurance!
Old Jan 26, 2015 | 05:59 PM
Reorge's Avatar
I drain and fill every 15k miles.
Old Jan 26, 2015 | 06:26 PM
Georgiey22's Avatar
Just like @Reorge I change at 15,000 miles. Very cheap insurance, the job only takes 20 minutes and gives me peace of mind.
Old Jan 27, 2015 | 07:42 AM
Schu's Avatar
does anyone have a link to a DYI of this service?
thanks
SidhuSaaB
May 30, 2020 12:40 AM
spudweb
May 22, 2016 02:39 PM
LeVeL
Oct 18, 2015 04:19 PM
hpfiend
Sep 27, 2015 06:59 AM
ROSSARONIE
Sep 22, 2015 11:46 AM
