Fastest j37
Old Jun 9, 2023 | 03:25 PM
2012shjseries's Avatar
Fastest j37
Anyone know what the worlds fastest j37 is? Link?
Old Jun 9, 2023 | 06:34 PM
altair47's Avatar
J37 is a thin-walled Open Deck that works almost at the limit of its power in stock, any kind of tune will lead to a quick reduction in resource, so J37 is not about race.
Old Jun 9, 2023 | 08:22 PM
MB7's Avatar
MB7
Fastest NA J37 belongs to Chony1703 from SMP Performance who's making 378 WHP on his third gen TL with a J37 swap. Fastest 4G J37 NA I believe is Prince Boodoo with around 340WHP and a 12.8 1/4 time. (If there's someone faster NA please correct me)
I'm sure there's a bunch of boosted J37's that are even faster but I don't know who they would be.
Old Jun 15, 2023 | 08:24 AM
you can only really boost them with the gerzy bear procharger can’t you? And I’m trying to find the fastest j37 even if it’s boosted, I want to see where mine could be one day. Ik gerzy bear is in the process of making a dual plenum so we can have 2 air intakes and I’ve heard ppl say we’ll be able to smoke vq’s.
Old Jun 15, 2023 | 08:26 AM
Hypothetically if I had the money for a forged block, heads, etc. could I not then push the power up really high. I know people sell like 800-1200 hp piston heads and rods, it would be nice to be able to put that power down in a 4g one day.
Old Jun 16, 2023 | 07:18 PM
MB7's Avatar
MB7
J37 is definitely weaker than the J35 variants but they can still hold decent power stock, dunno what that other guy is talking about. P2R's 4G drag car is a good example if you wanna look into that. And yeah the gerzybear supercharger is the tried and true method, although custom turbo kits can be made for sure, just needs a lot more time to plan everything
Old Jun 17, 2023 | 05:11 AM
altair47's Avatar
I think a good and cheap option for would be to get rid of the propeller shaft and instead put an 100 lb⋅ft electric motor.
Old Jun 20, 2023 | 04:42 PM
i follow p2r on most of their 4g stuff, some of the best out there for the 4gs in my opinion, there’s not much out there lol
Old Jun 20, 2023 | 04:44 PM
what is the propellor shaft, and by electric motor you mean replace my engine? Sounds like a cool idea but I’m more of a fan of burning fuel
Old Jun 20, 2023 | 05:29 PM
altair47's Avatar
Propeller shaft is what drives your rear wheels.
The front wheels will be ICE and the rear wheels will be electric.
Old Jun 20, 2023 | 05:36 PM
what does ICE mean? So you’d have an electric motor under the car? And how much power can a 100lb motor put out. The 3.7 would be putting all 305 hp to the front?
Old Jun 20, 2023 | 05:56 PM
altair47's Avatar
https://en.wikipedia.org/wiki/Intern...bustion_engine
With additional electric traction, the line marked with arrows will be at level 295fl-lb. and this is like on TLX Type-S.
The front wheels will have all 225hp. (305hp. is before transmission)
Old Jun 21, 2023 | 08:33 AM
the 225 is the stock whp for the 3.7? Also say I pumped the hp up to like 400whp would the electric motor even be strong enough to add any more power or would it almost make the car slower because it can’t spin nearly as fast as the front wheels? Also kinda unrelated but I found a user on Instagram that is making 501awhp on the 4g it says on his dyno. User is shawdytl pretty clean
Old Jun 21, 2023 | 06:19 PM
altair47's Avatar
Pretty clean - is when you shoot a car on a dyno with one video clip that accelerates and show the result on the screen. But one screen in poor quality is not pretty clean
Old Jun 22, 2023 | 10:45 AM
he says he’s going to have some pulls up soon. Assuming it is legit it will be pretty cool to see one with that much power. Idk what he did to it though even with the procharger, ported parts, bigger intake and exhaust and upgraded fuel line I’ve never seen anything go much further than like 400awhp
Old Jun 22, 2023 | 11:00 AM
dopeboy1's Avatar
The inconvenient truth
https://acurazine.com/forums/4g-tl-p...nation-974933/
Old Jun 22, 2023 | 01:29 PM
that is friggin sick man I’ve never seen that before. Is there a list of all his mods in that thread anywheres? Also it is a 3.7 correct?
Old Jun 22, 2023 | 02:38 PM
dopeboy1's Avatar
Some years ago I stumbled across this car for sale in Houston Craigslist after I had seen the thread. So I believe it's likely been sold to a new owner. Fortunately I copy pasted his build list from that for sale ad for us to dream about into eternity as we contemplate building our own cars. I understand it to be the 3.7 and yeah lots of custom work.
Fully Custom Turbo manifold, Down pipe intercooler and Cat back
Garrett GTW3884R (aka GTW6265R), 62mm Ball Bearing Turbo
Custom Intercooler set up with Garrett GT 24x12x4.5
Fully Custom hand made Turbo and hot pipe Heat shield
Brisk QR12LS High performance Spark plugs
Custom Engine Oil cooler located behind front grill
Tial Q Blow off valve
Tial MVR 44mm wastegate
AEM Wideband & Tru Boost Gauge
K Tuner Tuning software with custom AWD Dyno tune@500HP with E85
New oil pump and master engine gasket kit
Fully Serviced engine and Transmission
Spec Stage 3 racing clutch and Aluminum flywheel
Custom Dual Offset quad tips/Stainless Full 16 gauge 304 stainless steel cat back System
Bosch 1300cc injectors
Custom Dual Fuel Rail with -6an SS line
Custom -8an Stainless braided fuel feed & return line system
Fuel lab E85 fuel filter
Walbro 450LPH E85 Pump
Aeromotive fuel pressure regulator with 0~100 liquid filled fuel gauge
Spal High speed dual raditor fan with custom relay system
Custom hand made dual fan shroud
Optima Yellow top with custom relocation
Full adjustable BC coilover with custom swift spring
SPC Front & Rear Camber kit
Stoptech Custom slotted rotors and custom painted New OE calipers & Brembo performance Pads
Front Evo Lancer custom engine mount
Custom Big mouth OEM front bumper
Old Jun 22, 2023 | 07:22 PM
altair47's Avatar
They say it's better, cheaper and more reliable to buy a BMW M5
Old Jun 22, 2023 | 08:14 PM
damn he put some beauty work into that I can’t believe he sold it. Was the block stock do you know? We need to find the new owner
Old Jun 23, 2023 | 04:55 AM
he dm’d me a video of it last night and it’s the real deal it’s sweet asf. I don’t think he wants it posted just yet tho
Old Oct 7, 2025 | 07:17 PM
Wesley king's Avatar
I have plans for 490 whp and 550 chp with a rotrex c38-81 centrifugal supercharger.
Fahad
Sep 5, 2003 05:31 PM
BBsAcuraRacing
Aug 3, 2001 05:46 PM
