DRL LED or Switchback Problems
Old Aug 24, 2011 | 08:41 PM
chase101381's Avatar
Has anybody had any problems with there LED DRL or Switchbacks. I've read some articles of hot wires and melting and some with no problems. Just looking for advice? And were to purchase these. Thanks
Old Aug 24, 2011 | 09:38 PM
01stang's Avatar
http://store.ijdmtoy.com/
That's where I got mine, have mine on for about three wks no issues at all
I have seen hd wire harness u can buy I think for about $10 if u were that concern on oem wires being burnt.
Old Aug 25, 2011 | 03:12 PM
KB1Spec's Avatar
Testing out a module for the 09-12 TL today with full 12V power DRL LED. Will give you the out come later today.
Old Aug 25, 2011 | 03:26 PM
eazy's Avatar
WDP 4G
Could you refresh my memory a lil bit? V-Leds is coming out with this module?
Old Aug 26, 2011 | 12:02 PM
KB1Spec's Avatar
Sorry, I stop by my friend's shop yesterday and they were busy with bunch of customer car so he didnt have a chance to test out the new DRL harness.
As for as V LED. I'm not too sure about the revised DRL Harness for the 09-12 TL But I know V LED did come out a set of DRL Harness for the 07-08 TL and then they took it out from there site.
My friend tested out the DRL Harness on my car a month ago but the module was too hot so they had to revised the module to make it not too hot. So that is why they came out a new version of the DRL Harness for the 09-12 and waiting for me to test it out. But they were too busy last night so didnt have a chance. I will stop by after work today if they are not busy and keep you posted.
Old Aug 26, 2011 | 11:35 PM
jeffquadski's Avatar
Registered JEDI
Installed the ijdm kit tonight, very easy and the lights look great. There is a hole in the chassis just under each headlight that the Decoder's can drop right into. Will they get hot? Sure that's what they do, will it matter? They can't cause any damage as they are isolated in the holes. I'll report if I ever have an issue but all is good. BTW added the blue LED license plate lights too, they're sweeeeeet!
Old Aug 27, 2011 | 03:00 PM
Where did u get your LEDs from and which lights did u replace..... Like swithbacks, fogs, DRL etc
Old Aug 27, 2011 | 07:25 PM
Registered JEDI
http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r2.htm
Old Aug 27, 2011 | 07:56 PM
Mr Marco's Avatar
Will these work in my Ronald Reagan hot tub?
Old Aug 31, 2011 | 12:58 AM
KB1Spec's Avatar
Check my set up here for the fully functional 12V DRL LED with module
https://acurazine.com/forums/4g-tl-2009-2014-123/jlc-lighting-drl-led-module-09-12-tl-831247/
sockr1
Oct 1, 2015 01:31 AM
baowheezy
Sep 22, 2015 09:03 PM
JnC
Sep 11, 2015 06:06 AM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
