Custom Headlights and Tail Lights
Old Feb 28, 2020 | 08:27 PM
TRebelo's Avatar
I’m looking to get my 2009 headlights done black housing and smoked amber lense and also my tails smoked out with the black housing, are these still a thing? There used to be acouple guys on here who were doing it. Not that I can’t do it I’ve done it in the past vehicles I’ve owned but I just don’t have the patience anymore lol but I am tempt to just crack these open and do them myself but wondering if anyone is still doing this and pricing
Old Feb 28, 2020 | 09:21 PM
Riboflavin's Avatar
Ask Bruce, he runs www.endlessrpm.com, see if he's still doing them
https://acurazine.com/forums/members/acktl05-269877/
He did my headlights and taillights a couple years ago.
Old Feb 28, 2020 | 09:37 PM
TRebelo's Avatar
I tried clicking his name to message him on here but there was no message button so I was unsuccessful but I did go on endless rpm and contacted him thru that way. Waiting patiently for a reply
Old Feb 29, 2020 | 08:33 PM
TRebelo's Avatar
So for anyone wondering I heard back from EndLessRPM (Bruce, AckTL) and they are no longer doing headlights and tail lights. I might give this a try myself. Anyone ever take apart there tail lights??
Old Feb 29, 2020 | 08:35 PM
dopeboy1's Avatar
The inconvenient truth
Why not wrap the tail lights with laminx tint?
Old Feb 29, 2020 | 09:54 PM
TRebelo's Avatar
Mainly because I want to paint the bezel and outline on the inside of the tail light from the oem silver color to a satin black or gloss black and then tint them, I just like that look better imo, especially for the look I’m looking for. ACKTL style I like how those turn out.
I’m just trying to figure out now if the tail lights come apart with some heat like the headlights or do you have to cut with a dremel to get the lense off of them (I heard this was a thing)
Old Mar 1, 2020 | 08:39 AM
dopeboy1's Avatar
There are a set of tail lights for sale here with rose gold trim. Perhaps you can message the seller for more information as to how they were done.
https://acurazine.com/forums/market/985780
Old Mar 2, 2020 | 05:23 AM
KarKraze's Avatar
“Dopeboy” Rose Gold is Stock on the 2012 and up.
“TRbelo” , I did the Mod you are looking for on the Rear Tail lights. I can send you details later Tonight or look through my build Thread if you need the info right away.
Old Mar 2, 2020 | 06:09 AM
TRebelo's Avatar
That would be great if you can send me some details and tips later on. I’ll look thru your build thread also when I get some down time at work today. I appreciate it
Old Mar 2, 2020 | 07:10 AM
dopeboy1's Avatar
Oh really that is pretty cool. But then why is my 2012 chrome? Was it an option? How did that
​​work.
Old Mar 2, 2020 | 08:18 AM
vertigo2's Avatar
​​work.
My 2012 (Elite/Advance) is also chrome throughout the tail lights.
Old Mar 2, 2020 | 10:32 AM
KarKraze's Avatar
​​work.
Yes, officially it is a Red Chrome Trim and sometimes referred to as “Rose Gold”. It has a tendency to fade over time to more of a Pinkish hue, hence the term Rose Gold.
The 2009 to 2011 has a Silver Painted inner Bezel and is not as shiny as the 2012 /14.
Old Mar 2, 2020 | 10:38 AM
KarKraze's Avatar
“TRebelo” the info you are looking for starts at Post #691 on Page 18 of my build Thread.
Let me know if you need more info.
Old Mar 2, 2020 | 11:02 AM
TRebelo's Avatar
I actually went thru this morning and found it but during the process checked out the whole build all 24 pages. I must add incredible build and beautiful TL and best of luck with the Vette another beautiful car and I bet another great build.
So my only question is how did you rejoin the lense to the housing once you cut it and separated it with the dremel and what did you use to glue it or seal it back together.
Old Mar 2, 2020 | 11:14 AM
TRebelo's Avatar
I’m just surprised these can’t be heated up and just pulled apart without using the dremel to cut it all the way around.
Old Mar 2, 2020 | 11:24 AM
KarKraze's Avatar
I used Permatex Black RTV Silicone Adhesive Sealant.
Just an assumption, Probably a different bonding method.
On the headlights you can use a Butyl Windscreen Sealant which stays pliable and softens when heated.
Old Mar 2, 2020 | 11:29 AM
TRebelo's Avatar
Thank You, I’ll be stopping and grabbing these on my way home from work today, I appreciate all the insight and help you were able to provided, Thank you again very much KarKraze. Now I got my weekend project
Old Mar 2, 2020 | 07:31 PM
KarKraze's Avatar
You are welcome. Once separated, be careful with the inside of the Clear Outer Plastic housing.
There is a Clear Protective Coating (UV) on the inside so do not get any Rubbing Alcohol on it,If you do, you have to remove all the Coating, it also scratches easily. You will also have to re coat it if removed.
Don't seal it up too quickly, you have to ensure the Paint is fully cured, if you Seal it before the off gassing will create a haze / fog on the inside of the Clear Outer Plastic Cover.
Purchase the thinnest Ceramic Cutting Blade for the Dremmel, make sure you use Safety Glasses and long sleeves, when cutting the debris is very hot and the Blade tends to gum up easily.
Do not cut more than 1/8" deep or you may cut in to the Bezel, especially in the area that lines up with the Trunk.
Old Mar 2, 2020 | 08:17 PM
TRebelo's Avatar
awesome I will def be taking all this info, I’ll keep you updated. I’ll post some of my pics when done
Old Mar 9, 2020 | 10:08 PM
TRebelo's Avatar
So I did a thing, I was looking for a second set of tail lights to cut open and do the black bezel with the smoked lenses and as I was searching I found some tail lights that were exactly what I wanted to do to my own ones. The Red Smoked with the Black Bezel tail lights from Depo. They were $230 on eBay so I grabbed a set because I was going to end up paying $250 for a spare set anyway to try it on so why not rock these while I do the others with time. They fit up perfectly, nice quality, and plug and play and everything lights up fine no issues no errors popping up I even did a water leak test nothing happen no condensation or anything we’ll see with time but so far so goood but I will be taking apart the oem ones still and doing them on my own but as a daily driver I needed tail lights. I’ll get pictures of them installed it was getting dark out but these are them unboxed next to the oem ones
Old Mar 28, 2020 | 03:49 PM
Peakaboo's Avatar
3rd Gear
Looks great! Do you have any pictures of them on your TL?
Old Mar 29, 2020 | 07:15 AM
TRebelo's Avatar
I sure do, they look great, fit great, all plug and play and I’ve had no issues with them at all. Been thru 2-3 car washes now and it’s been raining the past week and no water issues or condensation build up. I’m very satisfied with them so far
Old Mar 29, 2020 | 07:36 AM
KarKraze's Avatar
Looks great !!
Just a suggestion....if you want to clean up the looks of the Tail Lights you can switch the Turn Signal Bulbs to Chrome covered ones.
This will eliminate the egg yolk looks in the Clear area of the Light.
Old Mar 30, 2020 | 09:53 AM
ripcityTL's Avatar
Super clean looking, looks great!
Old Mar 30, 2020 | 03:12 PM
MyGuti's Avatar
looks great, very subtle but nice upgrade
Old Apr 1, 2020 | 02:51 PM
Laer899's Avatar
New TL Owner
I recently purchased a TL too. Is there anyone left who does the headlight and tail light modification?
Old Apr 3, 2020 | 12:32 PM
jutes85's Avatar
It's very easy, you just put your headlights into the oven at 270 degrees for 10 minutes. Remove the three screws that hold the lens to the body and then peel back the lens. After that you can access to the housing and reflector for paint.
Old Apr 3, 2020 | 12:49 PM
jutes85's Avatar
Since I can't edit posts, here is a pic. Still a work in progress just waiting on parts.
Old Apr 3, 2020 | 04:04 PM
ripcityTL's Avatar
Can't wait to see it back on and finished up. I'd like to black out mine too, I've opened headlights on my previous car to install angel eyes so it should be similar. What paint did you use?
Old Apr 3, 2020 | 04:24 PM
jutes85's Avatar
Im also installing 4GTL-R projectors and Hi-Profile LED high beams/drls. I used typical gloss black paint and a couple coats of plastic clear.
Old Aug 29, 2020 | 01:09 AM
TRebelo's Avatar
For anyone curious just an update on the tail lights, so far so good 5-6 months later with no issues or condensation. Holding up well and I recommend them and they look great.
Another update I ended up doing my own black housing headlights.
Old Aug 20, 2022 | 10:13 AM
Christopher Michael's Avatar
toferdisobey
Hey I've been trying to find these. Do you have a link or what the title was? Thanks in advance.
AckTL05
3G TL Photograph Gallery
14
Jan 29, 2011 05:14 PM
AckTL05
Sep 3, 2010 06:53 PM
Mrtrak781
1G CL Photograph Gallery
Apr 25, 2010 07:56 PM
RelentlessOne
Apr 1, 2005 01:35 AM
6mtV6
Wash & Wax
Sep 19, 2004 01:53 AM
