Clarification needed please...B123 service
moabizzi
I have a B123 service reminder popping up.
oil change, cabin filter, tranny fluid, transfer case fluid, tire rotation.
for the tranny fluid and transfer case, is this a drain and fill, or is it a full flush reminder?
and how much tranny fluid do i need to order?
i can make a DIY if needed aswell.
I changed the fluids in my transfer case and rear differential last March.
Transfer case: 0.45qt (per 2012 SERVICE manual). I spilled some and still have remnants in the bottle from the 1 qt I purchased.
Rear Differential: 2.67qt (per 2012 SERVICE manual). I had 3 qts on hand and didn't use all from the third qt. You WILL need an oil bottle pump.
I also used all new plug washers.
moabizzi
i recently did my rear diff, so i wont need to do that, but i need to order the tranny oil from curry acura, weather just cleared up here in NJ, gonna be low 50s this weekend, looking to a lot of work on the car this weekend.
can anyone help me out and give me the name or even the item number of the tranny oil i should order?
moabizzi
082009008A
$6.42 per quart
does the transfer case use the same or does it use the DPSF like the rear diff?
moabizzi
im looking at the service manual, (got it from another source earlier, but thanks for the offer), and i cant find where it says anything about the front differential. i bought 4qts of DW1 and 1 of the DPSF. can anyone give me a heads up of where to look?
wusty23jd
09-24-2015 11:41 AM
asahrts
09-04-2015 05:55 PM
