Catalyst Temperature 446 Celcius???
Old Aug 28, 2016 | 05:09 PM
mossman77's Avatar
My OBDII scanner is reading a catalyst temperature of 446 degrees CELCIUS. This can't be right can it? I measured the inlet temperature of the front catalytic converter and got a reading of 480 degrees F and the outlet was at 380 degrees F. I then measured the under floor converter (under vehicle halfway back) and got a reading of 280 in and 180 out. This doesn't seem right to me at all. Shouldn't the outlet be about 100 degrees HOTTER than the inlet? I included some other screenshots as well in case anyone notices something suspect...
Old Aug 28, 2016 | 11:35 PM
Reorge's Avatar
446°C (835°F) seems realistic. Why would the outlet be hotter?
Unless your adding heat it can only get cooler.
Old Aug 29, 2016 | 06:39 AM
mossman77's Avatar
Because it causes a restriction and thus heat builds up inside. Every video I've watched on diagnosing a bad cat has sais otherwise, which is why I am questioning it. If it's normal, then that's very good news because replacing them is big $$$.
Old Aug 29, 2016 | 02:53 PM
Marmbo's Avatar
Quick search shows "The average light off temperature at which the catalytic converter begins to function ranges from 400 to 600 degrees F. The normal operating temperature can range up to 1,200 to 1,600 degrees" but I don't know what our cats run at normally.
Old Aug 29, 2016 | 04:47 PM
Anicra's Avatar
Should see the temp of C converter in a rotary engine
Old Aug 30, 2016 | 06:38 AM
mossman77's Avatar
No wonder the inside of my engine bay is hot as hell, because there are two cats under there.
Old Aug 30, 2016 | 05:02 PM
Anicra's Avatar
I just checked using Lemur Bluedriver ya that correct went from 600 to 880F easily
Old Aug 31, 2016 | 11:13 PM
Anicra's Avatar
Got it over 1000F last nite HA!
Old Sep 1, 2016 | 08:50 AM
mossman77's Avatar
Yeah, that was at idle. I measured 1200 F the other day when it was 90+ degrees ambient.
SCADAczar
May 3, 2016 05:48 AM
