Camshaft lobe inspection?
Does anyone know is it possible to inspect cam lobes without removing valve train?. I do hear little valve train noise I'm planning to check valve last this weekend. But from looking at images and video only way to inspect cam lobes is to remove valve train.
just got car back from acura of Bellevue. They did transmission flush, software update. Also noticed same valve train noise. They said most likely it is worn cam lobe.
the car just hit 110k, I'm planning on doing timing belt soon. And if I need to replace cam shafts it be time to do it.
Are you noticing loss of power or any flakes in the oil? Valves tend to be noisy on J-Series and an adjustment can quiet them down a tiny bit. Exhaust tend to tighten and intake loosen if I remember correctly. Takes about 2-3 hrs of labor and valve cover gaskets.
dealership changed oil 3 days ago. next time i will change and out the oil filter open and look for flakes. no power loss. the engine feels very strong. am, taking off valve covers today and check valve lash. maybe i can see cam lobes and look for wear marks,.
The gap can increase or decrease depending on where the wear occurs.... wear on the valve seat or face would decrease the gap, wear on the cam or in some cases a rocker or pushrod would increase the gap....
thus adjusted valves are happy valves
on these J37 engines, can we re use the valve cover seals, and also rep-use the intake plenum gasket? im planning on removing valve covers this morning, but if i cannot re use valve cover gaskets i have to wait and order a set before i remove them? i cannot remember if honda/acura uses rubber seal and gasket maker on valve covers?
I did see on the front valve cover on top left corner there was some gasket maker sticking out, so maybe acura uses rubber seal with some gasket maker on the corners?
csmeance (03-15-2021)
I just noticed something weird. The noise does not come on all time when cold and sometimes after it's hot. Example today I did cold start drive 50 miles no noise at all.
2 days ago cold start lots valve train noise.
I have contacted acura of Bellevue, doing oil consumption test. My car still qualifies for the repairs.. if they will end up doing repair I'm going to have them replace the bad cam shaft if there is one, since they have to take heads off anyways. And they will install new timing belt, I'll have them put new water pump.
