Valve tick or injector click or ?????
Old Jun 16, 2012 | 07:00 PM
jisleyjr's Avatar
I was changing the accessory belt tensioner today and i figured i'd get a video of my ticking noise.
It is only there under 1200 rpms and hot or cold make no difference. I've had this noise for well over a year, it has not gotten worse during this time.
At around 22 seconds the idle comes down and you can clearly hear it:
Right away sounds like valve train noise, so i think my tick is something else.
Thoughts?
PS. I have already done a valve adjustment and that made no difference. Sitting at 94k for mileage, original timing belt and components. Power and mpg are normal.
Old Jun 18, 2012 | 03:11 PM
LoveMyTL-S's Avatar
Anyone?
Old Jun 20, 2012 | 12:46 PM
jisleyjr's Avatar
Originally Posted by LoveMyTL-S
Anyone?
Looks like i stumped everyone!
Old Nov 8, 2012 | 09:18 AM
TrixR4Kidz's Avatar
well thought this thread may have solved my problem, which is the same exact noise from the same area. damnnnnnnit!! input from those highly knowledgeable acura gurus out there would be awesome!
Old Jul 23, 2015 | 06:59 PM
John4o1's Avatar
Same problem any one find a solution the sound is annoying!!!
Old Jul 23, 2015 | 08:24 PM
polish_pat's Avatar
Unfortunately the sound recording of a phone is really not the best thing to try and interpret a weird noise, to be honest, it almost all sounded the same to me except at the end, it sounded like the idler pulley bearing going bad.
When was your timing belt done? And if it was, was the valve adjustment done at the same time?
Old Jul 24, 2015 | 07:21 AM
jisleyjr's Avatar
Wow, I forgot I created this thread, its been awhile.
I still have the ticking noise. I changed t belt around 104k, everything was replaced including the tensioner pulley. This was probably 2 years ago?? I'd have to dig up some receipts.
I have 119k on it now.
Old Jul 24, 2015 | 10:17 AM
thegipper's Avatar
Have you ever checked that your spark plugs are torqued down?
I used to have a slight ticking noise and I noticed it went completely away after I found my #5 cylinder spark plug three full rotations loose.
If you haven't check all your spark plugs, I would make sure they are all tightened down correctly.
Old Jul 24, 2015 | 02:14 PM
jisleyjr's Avatar
Yes I changed the plugs around 95k and have checked them since when I did valve clearance adjustments. Nice and snug.
Old Jul 25, 2015 | 06:26 PM
truonghthe's Avatar
that sound from a bad tensioner.
Old Jul 26, 2015 | 09:14 AM
jisleyjr's Avatar
Nope, that was replaced during tbelt change. Sound was the same afterwards.
Old Jul 27, 2015 | 02:50 PM
truonghthe's Avatar
there are two tensioner, one for the TB and the other one for drive belt. Also check your alternator make sure the baring did not go bad.
Old Jul 28, 2015 | 10:16 AM
jisleyjr's Avatar
If you read the first post you'll see i changed tensioner for the drive belt and if you watch the video you'll see the drive belt isn't on, therefore it is not the alternator or another other belt driven accessory.
Old Jan 12, 2017 | 11:27 PM
Nick95TL06's Avatar
5th Gear
PLEASE PLEASE PLEASE, OP, have you figured out this issue? I've had the same exact problem for a year now and NO ONE is able to figure out what it is! I've spent countless hours digging through forums and youtube videos and facebook pages, you name it, and everyone has a different answer, no one seems to know exactly what this issue is even though several people are experiencing it. Any information would be extremely appreciated. I'm so sick of this problem, it's driving me insane.
Thank you.
Old Jan 13, 2017 | 07:29 AM
jisleyjr's Avatar
Thank you.
Good morning, i still have the noise and it hasn't changed any. Sitting at 131k miles now.
Old Jan 13, 2017 | 07:51 AM
nfnsquared's Avatar
IMO, that's too loud to be injectors. Certainly could be a loose valve. Have either of you ever had the valve clearance checked?
Old Jan 16, 2017 | 08:10 AM
jisleyjr's Avatar
Yes, that was something i did before making the first post.
Old Jan 19, 2017 | 11:04 PM
Si_jeff's Avatar
I am also having this noise but maybe not as loud. I can hear the engine sounding like a diesel on idle. OP - did you change hydraulic tensioner and tensioner roller pulley when you did your TB job?
Old Jan 20, 2017 | 07:05 AM
YeuEmMaiMai's Avatar
yeah it sounds like something knocking around the tensioner area.... that other tick tick tick noise is injectors....
Old Jan 20, 2017 | 07:45 AM
jisleyjr's Avatar
Yes, the kit i bought had those items.
Old Jan 20, 2017 | 12:58 PM
Si_jeff's Avatar
Thanks. And the noise is still there after the TB job?
Old Jan 21, 2017 | 11:51 AM
jisleyjr's Avatar
I still have the ticking noise. I changed t belt around 104k, everything was replaced including the tensioner pulley. This was probably 2 years ago?? I'd have to dig up some receipts..
Yes
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
TL14
Sep 24, 2015 04:37 PM
