Bug Splatters!
Old 08-10-2010, 10:57 PM
2010_TL's Avatar
Bug Splatters!
What do you guys use to remove the bugs that splatter on your front bumper without scratching/swirling the paint?
Old 08-10-2010, 11:03 PM
StuartMMVITL's Avatar
Clay bar with a micro fiber cloth works pretty good for me. I've also used Griot's Garage "Bug Off" which you need to apply first (after cleaning) as it will allow you to just wash them off easier the next time.
Old 08-11-2010, 05:59 AM
KeithL's Avatar
I keep the bumper waxed frequently and find the bug splatter washs off very easily.
Old 08-11-2010, 06:29 AM
andrec8513's Avatar
If there is a good coat of wax on the bumper, the bug stuff should wash right off!
Old 08-11-2010, 09:05 AM
COTM Coordinator
MurkyRiversTL's Avatar
I failed at the good coat of wax on the front bumper and now have perma bug splatter Its ok though, Im getting the bumper repainted anyway.
Old 08-11-2010, 09:14 AM
john94si's Avatar
Ancient chinesse secret..
Use a dryer sheet.
So use a fresh dryer sheet in your soapy bucket to wash the car and use that. It will wipe them right off without much rubbing.
I just used it on my 2 week old pearl white last night..worked great as usual.
Ive been using this method for years. And in Florida we have these things called love bugs. Your car can be covered within a 20 min dive like this in certain area during certain times.
Old 08-11-2010, 09:23 AM
CPR
CPR's Avatar
Love the dryer sheet idea; I'll have to try that
I've been using Nu-Finish, polish, for years, on all my cars
Takes the bugs off flawlessly, & leaves a nice lustre, with little effort
Old 08-11-2010, 10:45 AM
Oswald Vater's Avatar
Use a dryer sheet.
+1. I keep a few in my trunk for in-between treatment on longer trips. Haven't found anything that works better!
Old 08-11-2010, 12:51 PM
vinnier6's Avatar
thats got to be love bug season...
Old 08-11-2010, 02:50 PM
wmahmud's Avatar
Actually take the wet/soapy dryer sheet and wipe your car, or you mean just put a sheet in your bucket and that does something to the soapy mixture?
Old 08-11-2010, 02:55 PM
Takehold66's Avatar
^+1 That is what I was wondering also.
Old 08-11-2010, 02:57 PM
ScoobyZINE
AMUA6's Avatar
+1 on the dryer sheet, learned this one when I lived in Florida as well. I HATE LOVEBUGS!! but I love pulling them apart lmao
Old 08-11-2010, 03:09 PM
john94si's Avatar
No .. use it like a wash rag..but make sure it is wet and soapy before you rub the car with it.
Old 08-11-2010, 04:21 PM
xrays's Avatar
love the dryer sheet idea. will try it next time
Old 08-11-2010, 05:03 PM
csmeance's Avatar
Received 2,016 Likes on 1,435 Posts
I don't know how safe the drier sheet method is, but if it works go for it!
I use the soak method. Take some old blankets/towels and soak them in water and then apply ontop of the bugs for a few hours. It'd be best to soak them with a little bit of car soap added in. This way the bugs will rehydrate and be easier to remove. Follow up with a good wash and you'll be fine. For bugs that are stuck on really well, try using bug/tar remover! If that doesn't work, claybars work well, but will require a good amount of elbow grease!
Also check in our wash and wax section for more tips and tricks! As well there is some great info on washing and waxing!
Old 08-11-2010, 05:13 PM
2010_TL's Avatar
Thanks guys, I'll try some of these ideas. I already have some perm bug splatter. I dont know if I was to repaint the bumper, its not that bad.
I've read about the dryer sheet somewhere and I heard that it messes with the finish of the paint. Is this true?
Old 08-11-2010, 06:05 PM
john94si's Avatar
Ive used the dryer sheet on all my cars.. even black ones.
Old 08-15-2010, 09:31 AM
Kingmeow's Avatar
First time I've heard of the dryer sheet! I'll give it a try next time but I always keep the front facing parts (bumper, side mirror, lights, etc.) well waxed. No matter how bad the bug splatters are they come off pretty easy. I have yet to need Bug & Tar remover yet.
Old 08-15-2010, 11:56 AM
andrec8513's Avatar
Check out this Article. Should help!
http://www.autogeek.net/remove-bugs-...FdJL5QodPmt1aQ
Old 08-15-2010, 07:57 PM
Rocketsfan's Avatar
Any of you guys use denatured alcohol/mineral spirits? When they put the clear bra on my 3G, that's what they used to clean it. Didn't seem to damage anything, either. But I've also read that prolonged use of it could fade or fog a finish? I'm not sure.
Old 08-16-2010, 08:47 PM
Waaaaaaaaaa.
kooty-sentinel's Avatar
I applied a 3-stage wax (the brand is Mothers I think) after getting the car... and the bugs come right off with no problems most of the time.
After a long drive though I sometimes will go to a car wash and pressure wash the bugs off the front. Be sure to rinse only since the soap used at the self-serve car washes are usually low-quality.
ROWDY621
09-22-2015 11:02 PM
jblessing
Wash & Wax
09-17-2015 09:28 PM
SpraykwoN
ILX
09-11-2015 08:45 PM
NoleCLS
Wash & Wax
05-03-2002 11:27 AM
Quick Reply: Bug Splatters!
