Backup mirror not tilting sometimes
I've begun to notice that sometimes when I an in "R" the side mirror tilt function is not engaging. Sometimes I need to flip the mirror switch to the middle than back to the right(or left) side again. Sometimes I need to restart the car to reset something.
Anybody else with this problem? I'm wondering if there is a failing contact somewhere in the circuit. Such a trivial but nonetheless annoying thing.
um, you might need to disconnect battery to recalibrate the electronics in the car. sometimes that works.
try that if not, then there might be a fuse?
6G TLX-S
Bring it to the dealership. It's the power mirror module acting up.
Are you sure about the middle position? I have a 3G and it is definitely not the middle- you can choose either mirror side to tilt by moving the switch to the side. The middle position disables tilt in my car and I bet the same is with the 4th gen.
Oh man, you guys are funny. Did you open the owners manual or play with the switches at all? ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Now I know why Acura keeps its tech to a minimum. lol
Anyway, I think my mirror problem is bad contacts at the switch. Why? Because I've noticed it only when weather is cool/cold, when it warms up in the car it seems to work fine. So this morning when I started up in the garage the mirror was AGAIN not working. I then applied pressure on the entire switch while I slide it to L or R side and it worked like nothing was wrong.
We'll see how long this trick works but sounds like a bad connection that comes and goes depending on thermal material expansion/contraction....
ITSJESTER
17
12-06-2018 02:29 AM
soupi
14
11-15-2015 11:15 AM
