AWD Four Wheel Burnout
#42
Usually a lady has to buy me dinner first.
i dont think so.
it's gotta be a small hotrod trick or some sort.
cams, or maybe even head work.
but then the you would need a tune... even with a FI..you would need a tune.
a ported and polished intake manifold and its runners while boring out the throttle body would see gains without a tune.
If I didn't sound like a kid visiting toy-r-us for the 1st time I would
#44
Too soon, I'm just getting my beak wet. I have a few things in the works. All those supporting mods although necessary along the way are peanuts to an elephant compared to what I can already do. I've been considering a 4inch intake but I'm a bit reluctant to considering I just recently bought the CT-E intake and haven't done any air flow benching yet.
justnspace (03-21-2014)
HeartTLs (03-21-2014)
#46
Has flashpro come out yet? way to tune for the CTE SC? Intake size by itself is limited to how the whole system breathes, finding and reducing the bottleneck and tuning to get enough fuel to maximize the breathing ability.
#48
no, no ability to tune, yet.
if what I am suspecting he's done, he's minimized that bottle neck already....by boring out the throttle body and porting and polishing the intake manifold and its runners.
a decent increase in power that goes along with his exhaust mods!!
#49
Concerned about that tranny though!!
#50
#51
if I recall, we use the RL 3.5 cams. lighter, stronger, etc.
bisimoto re-grinds them and you can specify, according to your goals, how much lift and what kind of profile you want.
since, I dont know anything about the 3.7 I cant talk, or ill be making assumptions.
However, theres a guy on here whose has built a bottom end 3.7 with like 3.5 parts. I am unsure as his thread is too long for me to read, and simply idc.
but his user name is yungone532 or something like that.
#52
here's a current rotrex supercharger build:
https://acurazine.com/forums/3g-tl-photograph-gallery-96/pics-my-rotrex-supercharger-fabrication-project-907497/
here are his past N/A build:
https://acurazine.com/forums/3g-tl-photograph-gallery-96/second-leg-my-j-series-journey-my-race-built-j35a8-864372/
explanation of cams and what Bisimoto does:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/custom-bisimoto-cams-868611/
#53
here's the information about the 3.7 build. it's long. but its good. yungone owns a shop in dallas.
https://acurazine.com/forums/showthread.php?t=868611
#54
Your radar detector would be far more effective if it wasnt pointed to the ground like that
#55
I will have to read up on it sooner or later, Just not right this moment. I have a feeling the 3.5 and 3.7 are the same exact block, I could be wrong and I'm only assuming, but .2 liters isn't hard to make up.
#56
#57
this will tell you how the shop works
#58
Just saw the video, Carlos text it to me. The peeling out doesn't make justice, it really pulls hard guys. Carlos can you please post the video and text me the other one.
#62
A tune alone with no mods will make a difference. Not one that will have you breaking any records, but just firming up the shifts and the time in between will be an improvement.
#63
it ,however, will not bring big numbers.
the 3G crowd is seeing 10-15 peak hp.
for the amount of money for flash pro, it will help you further refine your ride and nothing more.
if F/I, flash pro will do great things for you.
#64
My goal, the potential is pretty retarded, it's hard to tell you what I can theoretically put down without giving it all away . This is my daily though so I can't go too bananas without really killing it's longevity. 400 awhp is a nice number, I need some dyno time to see what I'm currently putting down.
#65
So is yours the 2012 on youtube with nitrous? If not there's a black 2012 black/umber with an installed nitrous kit. The videos were posted a few weeks ago, but there is no video with the car driving, just at idle.
#66
We both know mines bigger . I'm just curious about others experiences on the matter, since a lot of guys here have different levels of bolt on's. I'd like to know at what point do you step over that line if at all possible. If possible though, I wouldn't recommend doing it often.
#68
Do you think that trans could handle that kind of power?
#70
That's not to bad for a stock trans. Are there any it's for these trans available to beef them up? I'm sure there is someway to interchange another trans with this drivetrain.
#71
Wow $3000 for a 2008 RL is a great deal!
#72
no no.
I havent found one and my expectations of it are VERY low. I know the perfect car for me will be beat up, high mileage, maybe some body work.
All I need it to do is run.
and this is my "dream" .
not even close to being realistic as I rather save my pennies for a place to live.
a second project car would be later in life.
#74
My dream is to find a non-molested Integra GSR or Prelude SH 5-spd. I know... almost impossible.
#75
I let my little bro drive my car once. He put it in neutral (Auto), revved it to about 4 or 5K and popped it into Drive. It chirped and the wheels spun a little before the power dropped and it gained traction and he is never allowed to drive my car again for the rest of his life ever.
Now when I had my S2K, I could leave rubber, but, it's an S2K. I don't dare try in the TL.
#80
I meant on dry conditions. Altering road conditions by oiling the street, tire soaking, steep uphills, also do not count; no aids. This burn/peel out is a product of power you're putting down. In case you're MT, it can also be a product of clutch mastery. So I ask again, 3.7'ers under dry conditions have you ever done an AWD burn/peel out? Not just chirping the tires for a fraction of a second.
Mods can I get a title edit? I'd like it to say: AWD - Four Wheel Burnout/Extended Peel Out
Not going to happen.
