Auto windows roll up module?
Old May 12, 2010 | 10:21 PM
FAST4DR's Avatar
Anybody install the Auto windows roll up module? I had installed one in my 2006 and loved it. Press the lock button twice, within 1 second of each other and the module would roll up all the windows and close the sunroof. A simple unit, but worked well. For those who aren't familiar with it, it simply sends 12 volts to the same wire that gets energized when you do this trick with your key in the door lock. I forgot to get the module out of my totalled 2006.
Old May 13, 2010 | 05:31 AM
Pseudomaniac's Avatar
I think if you hold the unlock, it rolls the windows down - but haven't found any other button pushes that do anything from the factory.
Now if they'd open source out the voice commands or release a software update with thinks like "Garage Door Up" and "Windows Down", "Windows Up", "Wipers automatic" - that would be big pimpin'.
Old May 13, 2010 | 07:08 AM
GunnerX's Avatar
Where did you get the module from? This is something I would definitely be interested in. I hate having to walk over and put the key in specially now that it's keyless for the 4G.
Old May 13, 2010 | 08:30 PM
FAST4DR's Avatar
KP Technologies. http://www.kptechnologies.com/products.php#/17
I emailed them to see if anybody had bought and installed one in the 4G yet. Haven't heard back. I can't see why it would be any different.
I did a writeup on how to install it, years ago on the 3G. Should be pretty similiar.
As soon as I hear back, I am going to order a module.
Old May 13, 2010 | 08:33 PM
FAST4DR's Avatar
I found the original thread I did years ago.
https://acurazine.com/forums/showthr...ow+roll+module
Old May 13, 2010 | 08:50 PM
GunnerX's Avatar
Thanks for the link. If you click on compatibility it does show 2004-2009 Acura TL. Which means it should work with the 4G.
Old May 13, 2010 | 09:17 PM
charco's Avatar
2009 TL SH-AWD Tech
I definitely don't want the windows up/down voice commands........imagine the computer mis-recognize your command as windows down when it's down pouring ........lol....
Old May 13, 2010 | 11:42 PM
Pete2010's Avatar
I would also be interested if the install isn't too difficult. Sounds like a great addition.
Old May 24, 2010 | 05:38 PM
potmilkz's Avatar
so anyone do this yet?
Old May 24, 2010 | 10:24 PM
With the 04-09 - I'm assuming they mean the 3g and that they haven't modified the product line to reflect the new model changeover. You see this on Ebay all the time as well.
Old May 25, 2010 | 12:40 AM
GunnerX's Avatar
Well, it seems the feature is identical between the 3G and 4G. Press the unlock button twice to roll down and use the key to roll up. I'm assuming Honda would have just used the same system so I don't see why the product won't work with the 4G.
Old May 25, 2010 | 08:42 AM
Pete2010's Avatar
Alright then, who wants to be the 1st to try it. Would this also close the sun roof also? That would be freaking sweet if it could do that too.
Old May 25, 2010 | 10:09 PM
FAST4DR's Avatar
Yes, it will close the sunroof (no matter the position) and close all windows; same as your key will do in the door lock. I'm ordering the module right now and will do an install writeup with pictures as soon as I get it.
Old May 25, 2010 | 10:28 PM
Pete2010's Avatar
Old May 25, 2010 | 11:00 PM
GunnerX's Avatar
Nice! Can't wait to hear the results!
Old Jun 21, 2010 | 02:03 PM
FAST4DR's Avatar
Just wanted to update, I did receive the module, but haven't had the chance to install it. So busy lately. Hopefully will get to it this week.
Old Jun 22, 2010 | 10:43 AM
NOX 3.2's Avatar
TL-SHAWD 6MT Rocks!
One module, or do you need one [$50] module per window + sunroof ?
Where does it go ?
Old Jun 24, 2010 | 05:23 PM
potmilkz's Avatar
update update!
Old Jun 28, 2010 | 01:26 PM
drek007's Avatar
Old Jun 28, 2010 | 10:06 PM
free598's Avatar
Im Broke But Im Ok
ANY--update
Old Jun 29, 2010 | 03:47 AM
charco's Avatar
2009 TL SH-AWD Tech
:gheywave:
Old Jun 30, 2010 | 08:58 PM
FAST4DR's Avatar
SUCCESS!!! SUCCESS!!!! I repeat SUCCESS! Wow, took me about 3 hours to figure it out. Of course, once I figured it out, I was like duh, that was easy. The directions kept throwing me, because I was looking for and found wires that had 5 volts when unlocked and 0 volts when locked, but they didn't do anything. There are two wires at the lock motor that have 12 volts and if you ground them, one locks the door and the other unlocks, same as turning the key. It's takes a little courage to ground wires with 12 volts in them and not expect to blow a fuse or burn something out.
So what the module does is watch for 12 volts to come across the door lock motor hot wire. When it see's 12 volts twice within 1.5 seconds of each other(from you pressing keyfob lock twice), it grounds a wire coming out of the KP box, which goes to the above mentioned lock wire and holds it for about 8 seconds, long enough to close the sunroof and windows. Same as you holding the key in the lock position in the door.
This will be easy for you guys to do since I will give you pictures and the exact wires to connect to. Pulling the door panel will be the hardest thing.
I don't have it finished yet, door panel is still laying on the ground and the wires are just pushed in where they need to connect. So tomorrow when I have more time, I will take more pictures and finalize the hookup, then do a writeup.
Will
Old Jun 30, 2010 | 10:46 PM
free598's Avatar
Im Broke But Im Ok
thanks alot cant wait
Old Jul 1, 2010 | 11:40 PM
GunnerX's Avatar
Nice! Can't wait for the instructions and pictures. I will definitely do this mod.
Old Jul 2, 2010 | 12:36 AM
charco's Avatar
2009 TL SH-AWD Tech
cool
can't wait
thanks for the great info
Old Jul 2, 2010 | 01:05 PM
free598's Avatar
Im Broke But Im Ok
i just order mine
Old Jul 2, 2010 | 03:38 PM
FAST4DR's Avatar
Originally Posted by free598
i just order mine
I'm working on the install directions.
Couple teaser pics. The door speaker is pretty nice for a factory speaker. Looks like polypropylene with a honeycomb pattern in it. The speaker has some decent excursion also.
Old Jul 3, 2010 | 12:21 AM
free598's Avatar
Im Broke But Im Ok
those speaker suck i just replace the 2 front speaker they were shot
Old Jul 9, 2010 | 04:42 PM
free598's Avatar
Im Broke But Im Ok
any update on the install directions.......im waitin to install mine
Old Jul 12, 2010 | 10:17 PM
FAST4DR's Avatar
Finally finished install instructions.
https://acurazine.com/forums/showthr...0#post12168510
Old Jul 13, 2010 | 03:16 AM
HAWAII-TSX's Avatar
Thanks fast. Really nice job on the pdf. Mine is being shipped and I will have it soon.
Thanks for all the info.
Old Jul 13, 2010 | 05:26 PM
free598's Avatar
Im Broke But Im Ok
Thanks---fast4dr -----great write-up
Old Jul 15, 2010 | 02:08 PM
potmilkz's Avatar
so one module per window? so i need all 5 which includes sunroof? how do you wire up sunroof?
Old Jul 15, 2010 | 03:48 PM
FAST4DR's Avatar
You only need one module! It's not controlling each window. It's only simulating what the car can already do. The car can already roll all the windows up and close the sunroof by holding the key in the door handle in the lock position. If you put your key in the door and turn to lock position, twice, the car will close everything. The module simulates this when it sees the door motor locking twice, like when you press the lock button twice on your remote. The module is mainly so you can close everything from your remote. Nice thing is you can get out and press the black lock button on the door handle twice too, and it will roll everything up.
Old Jul 15, 2010 | 08:18 PM
free598's Avatar
Im Broke But Im Ok
thanks again--FAST4DR----i install mine today it works great
Old Jul 16, 2010 | 01:45 AM
FAST4DR's Avatar
No problem. I seem to be using the black button on the door handle to roll everything up, more than the remote, since it is usually in my pocket.
Old Jul 16, 2010 | 12:42 PM
potmilkz's Avatar
so i can only install this on the driver side window correct?
also the instructions on the PDF includes the moon roof too right?
Old Jul 16, 2010 | 12:46 PM
potmilkz's Avatar
also you guys bought kptechnologies ITEM#HM20 right?
Old Jul 16, 2010 | 01:25 PM
free598's Avatar
Im Broke But Im Ok
correct..1 install control all 4 window N sunroof
le^2
Mar 17, 2026 05:06 AM
Jul 16, 2017 07:33 AM
DerrickW
Nov 15, 2015 05:52 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
