2012 Acura TL Base
Old Oct 26, 2024 | 10:39 AM
4GeezTL's Avatar
2012 Acura TL Base
Hello all,
Long story short, I know our radiator and condenser has two fans, and they operate at a low and high speed depending on outside temp and if AC is on or off.
I am sick of the on/off cycling of the radiator fans while stopped in drive and idling. It causes vibrations even in the seats; and idle dips to compensate.
This only is happening when radiator fans go into high speed, at low speed with AC on there is no idle dip and no vibration.
Question is, how can I make the car keep the radiator fans on at low speed all the time?
I have k tuner and HDS
New battery
new idler tensioner
new alternator
both new cooling fans
all new mounts OEM
Zero check engine lights, and zero misfires
thanks
Old Oct 28, 2024 | 06:02 PM
csmeance's Avatar
Try doing an engine mount neutralization to reduce the vibration, also idle relearn procedure.
Old Oct 28, 2024 | 06:43 PM
4GeezTL's Avatar
That’s a good thinking. I did do the mount neutralization method when I replaced the mounts.
I am leaning toward a voltage issue. However battery test good, alternator is a reman Denso, and starter is also testing good.
could it be a bad voltage regulator in the alternator I replaced? I don’t have any Check engine lights.
or could it be a bad EDL sensor?
In summary, when the car is at idle and the high speed fans kick on along with the AC compressor, this is causing the idle dip and raise then rhythmic vibration from the cooling fans.
Old Oct 29, 2024 | 06:13 PM
csmeance's Avatar
How low do the RPM's dip?
Have you cleaned the throttle body and checked the intake boot for cracks?
Check your A/C system too! if the compressor is working harder than it needs to be, then it's putting extra drag on the engine. It could be as simple as it being low on refrigerant causing the issue.
Dreamliner
4G TL Problems & Fixes
Jul 27, 2023 11:15 AM
GaRaS
Jul 13, 2021 10:23 PM
capper
Nov 13, 2017 01:47 PM
mnjeepmale
May 21, 2010 12:06 PM
RaleighNC
Feb 1, 2002 01:02 PM
