2012 Acura TL 3.5 Base 110K miles
When I turn the key off (engine running to engine not running) the #12 "meter" 7.5 amps Fuse blows Driver's Side Fuse Box. The engine runs fine until you turn it off. Then #12 Fuse Blows and the engine will just turn over not start until the #12 fuse is replaced.
Also, the Dash Cluster Gauges went out. I have no speedometer, tachometer, fuel, temp, blinkers, side mirror control, rear view mirror dimmer. Also, the radio works intermittently. Any suggestions thanks in advance.
Jd258
05-22-2021 02:42 AM
wagonfanatic
11-19-2020 03:05 PM
khines_13
01-28-2020 03:21 PM
evo190
1G TSX Problems & Fixes
11-14-2015 06:01 PM
