2010 TL Back seat removal?
I am trying to install some H&R sport springs that i purchased for my 2010 Acura TL and I am having some problems with the back springs. Does anyone know of a thread here in Acurazine that can explain how to remove the back seat so that i can remove the shocks in the back?
Thank you.
Thank you.
should be like most acuras.
there's a 10mm or 11mm bolt located behind each headrest.
and theres's a few 10mm or 11mm bolts in the crease where the top part and bottom part join.
lastly, there's clips on the bottom seat.
Click here for DIY thread with pics.
If you're doing this by yourself, when unhooking or pulling the back seat up, do not try to do it in the middle of the seat. You will struggle mightily. There are 2 hooks, one on each side. Unhook them one side at time. Much easier or just have 2 people on each side unhook it the same time.
Thank you.
Thank you.
http://heeltoeauto.com/gallery/index...TL-Springs-DIY
I used these directions to install my own springs alone.
