2009 B135 service
2009 B135 service
The guy is telling me i missed my timing belt service, spark plug service and a bunch of other things. My vehicle doesn't have over 136000 miles. When is the timing nt service due. It's not in my service book.
2011 SH-AWD 6MT
I believe most timing belts are due around 105,000. The minder should have reported it due a while ago as well as plugs. If you haven't had it done, it's definitely overdue for both.
Keeping TL until 2029
http://owners.acura.com/service-maintenance/minder?year=2009&model=TL#mid^UA8629JW
Typically Miles is here:
https://acurazine.com/forums/fourth-...g-belt-830338/
My only has 90,000 km and I thought I had to do it at 100000 km but my service advisor told me that I can wait until 150,000 km.
It's best to also do the 'water pump" + "timing belt' at the same time (from my research on the forums).
MM is here:
echodigital (08-24-2016)
i worked at a Honda dealer for several years. 7 years or 105k is the recommended. I have had customers pass 150k with no issues but I have also had the opposite. When it comes to the Timing belt. Just get it done. It should be a package. Timing belt, water pump, accessory belts, coolant, tensioner. If you can have them replace the idler pulley since it's like a bolt away from being removed.
Drei
05-06-2017 10:16 PM
