09 TL Runs Fine 15 Seconds Then Misfires
Old Feb 24, 2026 | 01:43 PM
tulsacars's Avatar
5th Gear
I have a 2009 TL. It starts up fine. Revs fine. Then after 15 seconds it starts misfiring.
Turn the car off, restart it and the same thing happens. Runs fine, then misfires.
Shows P0302 and P0306. I replaced all 6 plugs and coils. Same exact thing happens.
I tried clearing the codes. Same thing happens and codes come back. Sometimes a P0304 is also there.
It's weird how it runs and revs totally fine the first 15 seconds of every start, but then starts noticeably missing after 15 seconds.
Any ideas? I am stumped!
Old Feb 24, 2026 | 06:28 PM
altair47's Avatar
Tell us the story, after what and when it started, did you do diagnostics by date, did you replace any sensors?
How much did you pay and where did you get the coils?
Old Feb 24, 2026 | 08:59 PM
tulsacars's Avatar
5th Gear
I bought it at the auction this way. They are cheap Amazon coils and plugs. I don’t think that’s the problem. Like I said, it runs perfectly fine for the first 15 seconds or so and then all of a sudden it starts missing. Every single time. It’s almost like something in the computer just goes crazy. I have not replaced any sensors. There is no error codes for anything like that. Just the two or three misfire codes that show up.
Old Feb 24, 2026 | 09:21 PM
altair47's Avatar
Then the first and most important thing is to put the original coils back in place. Throw the Amazon ones in the trash or give them to your enemy.
The problem could be in the MAF, EGR valve, EVAP purge valve, or bent valves.
Old Feb 24, 2026 | 09:32 PM
tulsacars's Avatar
5th Gear
It had the same exact problem with the original coils and spark plugs. I don’t think the coils and spark plugs are the issue. It runs totally fine the first 15 seconds. Every single time it is started. And every single time after approximately 15 seconds it starts missing.
Old Feb 24, 2026 | 09:35 PM
altair47's Avatar
Where did I mention the coil was the problem? The coil simply needs to be replaced with the original one.
Old Feb 25, 2026 | 06:03 AM
tulsacars's Avatar
5th Gear
Same problem after original coils put back.
Old Feb 25, 2026 | 06:28 AM
altair47's Avatar
Of course, it's the same problem, nothing should have changed, just keep those coils away unless you want to turn your car into a stationary cart. Now make sure the MAF is clean and OEM.
Old Feb 26, 2026 | 06:17 PM
csmeance's Avatar
get a boroscope and put it down the spark plug holes, check the valves to ensure they are opening/closing properly. Also depending on mileage it could need a valve adjustment. Is it a FWD or AWD TL?
Old Feb 26, 2026 | 10:11 PM
tulsacars's Avatar
5th Gear
AWD. Someone else mentioned valve adjustment. But why would it be silky smooth the first 15 seconds or so every time???
Old Feb 26, 2026 | 10:27 PM
altair47's Avatar
I have a 2012 TL with 421,000 miles on the original engine. The valves have never been adjusted, and the engine runs smoothly. I know that in the CIS, we have poor gasoline quality and valve adjustments are recommended every 100,000 km. However, this can still cause the engine to run slightly unevenly, but I've never seen misfires due to poor valve clearances. Have you checked the MAF?
Old Mar 8, 2026 | 01:46 PM
mdx'er's Avatar
Do you actually hear it misfire and how does it drive after that ?
What are your fuel trims ? O2 sensors ? EGR ? maf and iat sensors ?
Have you tried doing a ecu reset and see if it goes away at least for a longer time ?
I suspect some pcm event is happening after it warms up like loop open/close or fuel trims going from idle/start level to normal operation level. After you have tried a full reset monitor via obd fuel trims, O2 sensors, EGR, IAT and MAF sensors see if they are reading normally.
willr22
4G TL Problems & Fixes
Jun 26, 2025 03:36 PM
stealthrz
17
May 10, 2021 06:11 PM
eez4life
Apr 4, 2013 08:40 PM
achanna
Dec 16, 2010 04:36 AM
cbusAcuracls
Jun 3, 2008 06:48 PM
