2022 MDX Advance ELS Audio > Poor or Lack of Bass
First time owner of a MDX Adv. Not sure if I have a defective ELS Premium audio system but there's very little or lack of bass. Is there any suggestions or solutions from other 2022 MDX Adv? Something I need to adjust? High Treble and Mids but bass is disappointed as if it's non-existent. Appreciate it and look forward to other opinions! TIA!!!
Tested w Android Audio Spotify
6G TLX-S
Good, solid bass requires a sealed cavity for resonance. Unfortunately, SUV's are not cars. The trunk of cars can function as a sealed cavity for decent bass generation. But the trunk area of the MDX is wide open, and not sealed. As a result, the bass response on the MDX is poor. Other than the bass response, the ELS sound system is very good.
The only way to get excellent bass on the MDX is to fabricate a sealed box to house the subwoofer speakers, or just better bass by installing compact powered enclosed subwoofer such as the Kenwood KSC-SW11.
You mentioned a small compact subwoofer. The enclosed ones that can fit under the seat? You have an recommendation of model numbers? What do you use to tap into the White & Red Audio inputs?
E92Vancouver (09-18-2021)
I have a 2018 and with the dynamic bass? setting to high, it has plenty of bass. Not shake your neighbors windows bass, but plenty for those inside the car. Is the 2022 different?
2022 MDX Advanced
SoCalBills (09-07-2021)
Agree on clarity and volume is pretty decent. Disappointed they used a low quality woofer. Can I swap that out with another 8-inch woofer works well with the factory amp?
here is one that may fit but expensive: Rockford Fosgate P3SD2-8 8" Dual 2-Ohm Punch Series Shallow Mount Car Subwoofer
https://www.amazon.com/Rockford-Fosg.../dp/B008GTWAI2
Anyone upgraded their MDX 2022 stock sub yet with these or similar?
2022 MDX Advanced
Just tried it with this 8” / 2 ohm / 97 sensitivity woofer. Sounds worse. Not enough power from amp. Getting my slim JL 12” box next week to lay in the cargo cut out (fits perfectly btw).
https://smile.amazon.com/dp/B07VKQ4P...ing=UTF8&psc=1
2022 MDX Advanced
remove the factory 8”, use those speaker level outputs to a line out converter, plug the RCAs into the amp, then connect the sub to that amp.
Can you provide the model # of the JL Box?
2022 MDX Advanced
https://www.crutchfield.com/p_136112...112LG-TW3.html
Oh no in the middle…the volume isn’t going to be enough in the side areas. Lay it down in the middle cut out and point it up.
Cool..thanks. was browsing around and found these min-amps for driving sub-woofer. may be able to add a piece of plywood to that hole and mount it there and hide.
https://www.crutchfield.com/g_463350...Mono_Subwoofer
These are regular sized amps: https://www.crutchfield.com/g_120/Al...ers.html?&pg=2
2022 MDX Advanced
Niiice. Those are tiny - that Alpine one looks great. I really want the remote bass control knob so I’m going to try an fit my JL JX500/1 in there, but it’s going to be tight. Taking out the 8” and putting the amp in that hole is my plan.
2022 MDX Advanced
