Xxr 530
Old 11-02-2011, 01:45 AM
jwr0ng626's Avatar
Xxr 530
so who is getting these first?
I'm sure fitment will be similar with the 527.. so don't think we need to discuss that any further. These are beautiful wheels with (what looks like) a decent amount of concave
not feeling it too much on this tho..
Old 11-02-2011, 06:43 AM
Chapter Leader (Houston)
TLDude876's Avatar
Received 1,085 Likes on 810 Posts
Hmmmm, should I?
Old 11-03-2011, 01:41 AM
jwr0ng626's Avatar
lol If you could, are you gonna go with same size?
Old 11-03-2011, 09:16 AM
MrRicci206's Avatar
will probably be ordering these sometimes before christmas, most likely mid december.. what size should i get? its either between the 18 X 8.75 et 20 or et 35 or the 18 X 19.75.. am lowered on tein stechs.. about one and a quarter inch drop
2Morrow (10-13-2013)
Old 11-03-2011, 09:20 AM
Chapter Leader (Central Florida)
LostSol's Avatar
absolutely might, 18x8.75 +20 and 18x9.75 +20 would look purrrrrfect
Old 11-03-2011, 09:24 AM
MrRicci206's Avatar
would rubbing be a problem with 9.75.. would probably run 225/40/18 or if possible with the mild drop i have 235/40/18
07_TL_S (03-23-2014)
Old 11-03-2011, 09:30 AM
LostSol's Avatar
^ If youre concerned about fitment look for the XXR 527 fitment thread, it was discussed many times over there and this wheel will fit exactly the same.
Short story, 9.75 +20 wont rub if youre rolled and stretch
MrRicci206 (11-03-2011)
Old 11-03-2011, 12:17 PM
jwr0ng626's Avatar
yup. I ran a 9.5 +22 with 225/40 without rolling fenders and it fit without rub.
I'm thinkin of 18x8.75 +20 square fitment
Old 11-03-2011, 08:13 PM
mrlal8's Avatar
alright whoever does choose to get these rims...get 9.75 +20 ALLLLL around
whatever is said in the other thread about shaving fenders n such is just extra work you do NOT need to do.
I am runnin 19x9.5 +22 on a 225 tire...and I am pretty low.
The rears are rolled completely but i left the front stock...you will rub a little over extreme dips but your fenders will naturally mold to you rims then you will be fine for every future rim setup.
Old 11-03-2011, 08:43 PM
TLDude876's Avatar
^that's quite a lot of stretch tho
Old 11-03-2011, 09:52 PM
jwr0ng626's Avatar
^is it possible it run 235/40 on the 8.75 without rub on stock fenders?
or how about 245/40
edit: i doubt it... it looks like it'll be too close....
here's a pic of ur car for those who don't know lol
Old 11-03-2011, 10:00 PM
Fearless DIY Guy
DeathMetal's Avatar
Those will poke, you're running about 1/2" wider than the 8.75 et 20, which is a few mm shy of flush in the front. You're going to need to stretch to the point of stupidity to make it work without running some change in camber in the front.
or how about 245/40
235? Yes, that wouid work.
Old 11-03-2011, 10:04 PM
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Boy....those really bring to mind a Type S wheel.
Fearless DIY Guy
DeathMetal's Avatar
I personally do not advocate my wheel/tire combo slamming in to my fender to "form" the necessary clearance. That's just being sloppy.
Originally Posted by TLDude876
Hmmmm, should I?
Your girl is gonna kill you, bro...
Of course I'm going to recommend you do it, though
Old 11-03-2011, 10:17 PM
TLDude876's Avatar
^haha I just said to her the XXR 530 is out and before I could finsih she said NO!
235 or 245 can work, it just depends on how low you want to go. If I do get a set, I'll be getting the same size and offset. IMO that is perfect for the car as it looks clean and at the same time the ride quality is retained.
Old 11-03-2011, 11:12 PM
Dsrtne1's Avatar
Love these rims, reminds me of the forgestars. Just wish they made it in 19" so I wouldn't need new tires!
Old 11-04-2011, 02:41 AM
mrlal8's Avatar
i was going to shave my fenders but Bforbrian actually recommended this to me and we all know the vast amount of setups hes been through. This is not sloppy in anyway. Shaving your fenders and messing with the formation and strength of how the oem fender was built is sloppy IMO. When the tire hits the fender it is only the inner part that you cut out thats being hit. It does not affect the tire in anyway nor does it affect the appearance of your fender. Only when you go over extreme bumps will you hit the very inner portion of the lining that you cut off. My rear fendors are rolled paper thin to the point where its basically non existant and my next setup I am sure I can run an 11 inch wide rim in the rear which I plan on doing. By refusing to shave the front fenders not only did I avoid having to put some clear coat on the shaved portion....but I also kept the strength and formation of the OEM fender shape.
Old 11-09-2011, 11:56 PM
jwr0ng626's Avatar
oh guiterplayer.... I need your professional assistance
can I get a PS please?
Old 11-10-2011, 11:54 AM
cokorote's Avatar
or how about 245/40
Good question jwr0ng. So if I have 235/40 or245/40 the same drop as TLDude I need to work with the front camber? So how many negative camber do I need?
BTW TLDude I love your set up.
Old 11-10-2011, 12:35 PM
murph145's Avatar
haha Jeff you want some new rims!! thought you were done playing with the TL and only messing with the S2K these days
those are sweet XXR rims i seen them at SEMA and they look good for the $$
Old 11-10-2011, 01:33 PM
jwr0ng626's Avatar
prob need >1.5 neg camber with roll/cut fenders.. I want to try and stay around -1 at most
I always want new toys I have too many expensive hobbies... lol I love the style of the wheels but don't know what finish I want them in
Old 11-10-2011, 02:20 PM
TLDude876's Avatar
I am running -1.8 up front and -2.5 in the rear
Old 11-10-2011, 02:41 PM
jwr0ng626's Avatar
holy! would negative 1 to 1.5 work all around?
Were you forced that amount of camber or prefer it?
Old 11-10-2011, 02:43 PM
cokorote's Avatar
thank for the answer jwr0ng. I'm with you in running no more than -1.0 neg camber.
wow -1.8 front and -2.5 in the rear with the 225/40 all around??? that will eat your tires fast don't they?
Old 11-10-2011, 03:06 PM
myron's Avatar
what are factory spec limits for camber? -1.8 and -2.5 doesn't seem that much at all. That was close to my specs after I lowered the TL and drove like that for 3 years with not too much camber wear.
Old 11-10-2011, 03:23 PM
TLDude876's Avatar
That's the best the guy could get it with the toe in spec
Indeed, once your toe is in spec you should only have minor camber wear. My tires are still in pretty good shape
TIres are still like new with minor wear on the side. Toe is what eats tires, not camber
Old 11-10-2011, 03:46 PM
jwr0ng626's Avatar
I know toe is the main thing to watch out for, but I just don't want to have it out of factory settings.. the most I would want to go is -1.5
Old 11-10-2011, 04:26 PM
TLDude876's Avatar
You'll probably need upper arms for the front and upper and lower for the rear to keep everything in spec and be that low
Old 11-10-2011, 06:20 PM
jwr0ng626's Avatar
I think the car looks lower than it rly is lol I have 1-2 finger gaps all around
Old 11-10-2011, 08:14 PM
TLDude876's Avatar
I was making reference to my height. With your current height you should be good
Old 11-14-2011, 07:06 PM
Bbtfreeman04's Avatar
yup gettin these
Old 11-14-2011, 07:16 PM
baller on a budget, b!tch
AcRightLINY's Avatar
Look identical to my rims except non staggered and an inch smaller.
Old 11-14-2011, 08:19 PM
biffaroony's Avatar
on 530's
Old 11-14-2011, 09:15 PM
jwr0ng626's Avatar
ur wheels look awesome.. sorta what pushed me towards these
I love mesh wheels.... but everyone has em and I think i'll get bored too quick..
AcRightLINY (11-19-2011)
Old 11-19-2011, 11:06 AM
Yeah I love my wheels! These look great, I know that 04komodo was looking for an 18" in the lc style, hopefully he sees this thread!
Old 11-19-2011, 11:25 AM
Resident Dingo
TheDingo's Avatar
what size wheels and tires did you go with on your car? also, did you have to do any special stuff for fitment? how's your camber?
Old 11-19-2011, 11:33 AM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Can't sorry lol
I'd need a picture of the wheels head-on to photoshop onto your picture but I couldn't find any on Google.
Old 01-03-2012, 01:49 AM
06tl4life's Avatar
anyone order these yet?
Old 01-04-2012, 02:18 PM
hmmmmmm...oh wait... nvm.
Black_Hawk_TL's Avatar
ima get this in chromium black 18x8.75 +35 or +20 ....im bone stock... whats better ?...not putting any brembos maybe just a drop of 1.5-2.0"
Old 01-04-2012, 02:31 PM
jwr0ng626's Avatar
+20 with 235/40 or 225/40
Black_Hawk_TL (01-04-2012)
Quick Reply: Xxr 530
