Will it fit?
Will it fit?
Hello, l wanted put some rims on my car but I'm not sure if the rims will fit my car I have 2006 acura tl 6 speed and everything else is stock on car but the rims I am looking at are 275/30/20 on the rear not sure of the off set and the front are 245/35/20 and also will it rub?? If so what can I do to avoid it from happening ??? Thanks
That's website where I found them but here specs
Model - Legacy LG12 - WDG LG12
Size - Front 20 x 8.0 / Rear 20 x 10
Bolt Pattern - 5 x 114.3 ( 5 x 4.50 )
Offset - Front +34 / Rear +40
Hub-bore to fit - 73.1mm
1. they are ugly. it will not look good on the TL. there are better styled wheels than those.
2. why do you want to run a staggered set up? you wont be able to rotate tires, thus spending money when your tires wear out.
3. specs are weird. the front rims are way too weak and the rear is way to aggressive. (this is because its staggered)
you'll need to roll your fenders and do major body work to fit a 20x10 wheel in the rear.
4. our hub bore is 64.1
5. you'll need to choose a different rim
chedda13bc (06-27-2013)
This! Annnddd the thread can be closed! Research is your friend now that you know the original G wheels will not work.
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
