will 19x8 et25 fit my tl
hi, im just curious if 19x8 with et 25 fit my front wheels with 235x19x35 tires. also will 19x9.5 with et 35 with 265x19x30 fit the rear wheels
Too Fast TOO FURIOUS
When compared to stock wheels 17x8 +45mm, those 19x8 +25mm have the follow results:
Inner Clearance: 20mm MORE (the inside of the wheel to the strut housing)
Outer Position: EXTEND an extra 20mm (position of the outside edge of the wheel)
20 millimeters = 0.79 inch
94 DC4 RS LSV/Turbo
19x8 +25 will only clear if you use 225/35-19 tires and you probably won't be able to lower the car
19x9.5 +35 will clear with 265/30-19 but again you probably won't be able to lower
imo I would not go lower than 19x8 +32 in the front and 19x9.5 +38 in the rear
'06 750Li Sapphire/Creme
Retired!!! ON TOP!!!
ABSOLUTELY YES...
You will have to roll your fenders in the rear...
It also depends on the tire brand you'll be using... for example if you use DUNLOP tires they usually have a very bulgy sidewall and will Rub... but if you use the Falken tires they are tailored to the VIP scene and have a more slanted sidewall...
19x10 +35mm ---- 275/30 Dunlop
FizzyStatus!
Originally Posted by ndabunka
NOPE - WON'T FIT. I have 19x8 with a 30 offset and 245/35-19's (all 4 wheels) and they will rub (in the rear) every once in a while over major bumps and/or while corner VERY hard. a 25 offset pushes the tire out EVEN further so with a similarly sized tire as I have, it would also rub only worse. As far as 265 width goes...you would need a wheel with AT LEAST a 40 offset to have ANY chance at working.
emailnatec
29
09-28-2018 04:27 PM
xsilverhawkx
09-28-2015 06:51 PM
